Issue #7338 - Cutting a sphere results in errors after merging with other objects
dschoni
Post by dschoni »
Try this:
Torus:
R1: 10mm
R2: 5mm
Angle Y -90°
Position Z: -Radius1
Sphere:
R: <<Torus>>.Radius2
Position Z: <<Torus>>.Radius1
Box:
Length: <<Sphere>>.Radius * 2
Width: <<Sphere>>.Radius
Height: <<Torus>>.Radius1 + <<Torus>>.Radius2
Position X: -Length / 2
Cylinder001:
Radius: <<Torus>>.Radius1 + <<Torus>>.Radius2 + 1mm
Height: <<Torus>>.Radius1 + <<Torus>>.Radius2 + 1mm
Position Z: -<<Torus>>.Radius1
Angle X: -90°
Cylinder002:
Angle X: 135°
Fusion001:
Merge the Cylinders
Cut001:
Cut Torus with Fusion001.
The Result should be a small segment of 45° of the Torus.
Cut002:
Cut Sphere with Box
Angle X: 45°
The Result should be a half a ball on the lower side of the Torus segment.
Fusion002:
Merge Cut001 and Cut002.
Result: Nothing - Resulting Shape is invalid, internal Name Fusion002.
This is obviously a bug.
Reason: Added GH ticket number to thread title
adrianinsaval
Re: Cutting a sphere results in errors after merging with other objects
Post by adrianinsaval »
file? full freecad info?
Right now I'm too lazy to follow all these instruction but my first guess would be some sort of issue in occt's boolean operations, we know occt has it's quirks with coplanar/coincident faces or edges so it's probably that.
adrianinsaval
OP created issue #7338, please read and follow the guidelines and don't create github issues without getting feedback on your thread, and if you create an issue you should link it here too.
user1234
Post by user1234 »
dschoni wrote: Mon Aug 08, 2022 1:39 pm This is obviously a bug.
To be honest, without a file, it is not confirmable, since you can have slight missalingment, when it is not well placed.
Greetings
user1234
Post by Kunda1 »
dschoni wrote: Mon Aug 08, 2022 1:39 pmTry this:
Do you mind providing a file or files for us to reproduce?
Re: Issue #7338 - Cutting a sphere results in errors after merging with other objects
Post by Kunda1 »
bumping
Kunda1 wrote: Wed Nov 23, 2022 10:14 ambumping
No need to bump as we still wait for @dschoni's file.
easyw-fc
Post by easyw-fc »
It would be nice to check if using fuzzy boolean on the shape could solve this OCC coplanar issue.
adrianinsaval
Sample file is now available on the GitHub issue
easyw-fc
Post by easyw-fc »
attaching the file would have avoided losing time :lol:
Sphere-Problem.FCStd
(22.14 KiB) Downloaded 12 times
Sphere-Problem-fuzzy.FCStd
(31.54 KiB) Downloaded 13 times
unfortunately fuzzy is not parametric atm (it could be done with some python code)
