[Resolved] 3 lines to crash FreeCAD (reproducible) in Python console
obelisk79
Re: 3 lines to crash FreeCAD (reproducible) in Python console
Post by obelisk79 »
If the behavior regarding the empty non-indent line is consistent and predictable, could freecad just check for this condition and insert as necessary? I suppose it's a bit hackish but if a direct solution isn't apparent it would at least be functional.
TheMarkster
Post by TheMarkster »
Crash happens here:
https://github.com/FreeCAD/FreeCAD/blob ... e.cpp#L193
    Py_DECREF(args);
The argument args is null where there is a crash. If we change it to check first for null before calling Py_DECREF() the crash can be averted. But you still get the exception mentioned already about argument "source" missing. There is probably a better way to fix it, but I'm not sure how.
Actual crash happens in Py_DECREF() itself.
mfro
Post by mfro »
TheMarkster wrote: Fri Aug 05, 2022 10:45 pm Crash happens here:
    Py_DECREF(args);
Actually, the culprit appears to be before. It seems the Python compile chokes on illegal (i.e. not Latin1) characters in the command string that seem to come from a failed QString::toLatin1() call: one of the 'ß's is converted fine while the other one ends up binary-wise as 'not a unicode character'. Not sure if its worth investigating any further or if its good enough to just bail out if the compile failed.
Cheers,
Markus
TheMarkster
https://github.com/FreeCAD/FreeCAD/pull/7323
This PR just checks for the nullpointer before calling Py_DECREMENT(), which might have unintended consequences, like memory leaks.
@wmayer Can you review this when you get a chance please?
Founder
Post by wmayer »
TheMarkster wrote: Sat Aug 06, 2022 5:38 pm @wmayer Can you review this when you get a chance please?
If fixes the crash but the preferred method is Py_XDECREF because compared to Py_DECREF it checks whether the argument is null and only if it's non-null it decrements the counter.
However, the PR won't fix the problem why Py_BuildValue() fails to create a string object. I will have a look at it...
Founder
Post by wmayer »
git commit c4547c03e1 fixes the crash and UTF-8 problem.
TheMarkster
Excellent. Thanks for the fix and the explanation.
a.l
Post by a.l »
+1 Thanks =)
