Coil Around A Rectangle
Re: Coil Around A Rectangle
@mario52 The wiki says Python2 is required. Is that so?
Aloha edwilliams16
make today with
mario
make today with
OS: Windows 10 (10.0)
Version: 0.21.29485 (Git)
Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: French/Mars(fr_MA)
Installed mods:
Yes but the wiki page mention in "the index" "Python2 required" and in the first sentence.mario52 wrote: ↑Tue Aug 02, 2022 9:10 am Aloha edwilliams16
make today with
marioCode: Select all
OS: Windows 10 (10.0) Word size of FreeCAD: 64-bit Version: 0.21.29485 (Git) Build type: Release Branch: master Hash: a236ca843fdd6674afb6d7ed1454fbd3b547f5ea Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3 Locale: French/Mars(fr_MA) Installed mods:
https://wiki.freecadweb.org/Macro_FCSpring_On_Surface
Plus this sentence is not very clear:
Probably is a remnant of other things, or it was an early explanation of the "Coordinate Begin" values?The value of the height of the BoundBox of the object, the X value of the center of the BoundBox, the Y value of the center of the BoundBox, and the Z value of the base of the BoundBox.
Regards
Carlo D.
- Various other stuffs.
Hi
yes transition Pyside to Pyside2 now text is not current
mario
yes, calcul the BounBox center and begin in base of the BounBox
mario
The method of using the Draft Workbench as I mentioned earlier seems to be working fine, but I discovered that if you do not include the units when you enter a dimension in the Draft WB, it assumes mm. I should have started my project using mm, but I started with inches. I thought if the preferences was set to inches, all of the dimensions would be in inches, but in the Draft WB, if you do not expicity input the units as "in" or ", it assumes mm. That caused me a lot of confusion and waste of a lot of time. Also, the Table of point coordinates in a polyline are shown in mm even though the preferences is set to inches - more confusion.
The FCSpring_on_Surface macro looks like what I was looking for earlier. I will try it later on. I don't want to try it now because I have had some bad luck with macros in the past and had to uninstall FreeCAD and reinstall it to get rid of the problems one of the macros caused so I am a little leery to use macros. Looks very good though. None of the examples show wires wrapped around rectangular objects though.
Result of my most recent attempt at using FreeCAD to model an idea.
https://www.youtube.com/watch?v=t-pAukX8jEE
