mfro wrote: ↑Tue Jul 12, 2022 10:07 am
Because of that I actually didn't want to post anymore in this thread, but anyway, since you addressed me directly...
I understand what you mean. I also was a frustrated frog and need to rest the discussion for a few days...
grd wrote: ↑Wed Jul 13, 2022 5:15 pm
When you only have ONE object, the display is always completely correct.
Not necessary. I had a project some time ago where we had to model things on the place where they are in assembled state. in this way it is easy to place them on CSYS / default. If you have an object 200 x 300 mm and more than 1.5 m of CSYS images are almost useless.
It is better then no image... but it is still.
Also a nice one is that some companies want the objects the collor as they have in real live and specially with black ojects a picture is worthless...
adrianinsaval wrote: ↑Tue Jul 12, 2022 1:34 pm
FALSE and on the contrary, this is what would happen if grd's proposal were to be implemented. He wants to forbid the current behavior of FCStd files that allow multiple objects in it. Flexibility is exactly what FreeCAD offers already.
Okay, maybe i had taken a shortcut too. i never intended to forbid the current way since it is weird the force a part and assembly in arch or draft...
I always intended it as extra options.
drmacro wrote: ↑Tue Jul 12, 2022 11:02 am
I think the OP is of the opinion that splitting things to multiple files would improve the general performance of the application. I didn't think it was an improvement in workflow or user experience thing.
I differ in this (what probably didn't make the discussion better) But i think it is the reversed.
Splitting in multiple file types make it possible to choose the file type i need to edit (Within FC but also with sorting in the OS File browser). It makes it more visual which files have already a drawing and which ones doesn't. When using version history there are options to edit only the drawing (typo's etc) without changing the base model(quite often the discussion from 2.0 to 3.0 OR 2.0 to 2.1)
obelisk79 wrote: ↑Tue Jul 12, 2022 10:47 am
So, and I have asked about this before in this thread, what enhanced usability does this proposed change functionally bring to the table that you don't already get through the 'workaround'.
Because the essential point of a work around is that you can do something but it's exactly not as good as intended.
A small example my accu drill has a max drill size 12 mm. If for some reason i need a bigger hole, first i take the biggest drill that fist, then i make a hole. after that i take another dril and try to remove material from the side up to the required size....
It works but it are never nice round holes and the Cylindricity is equally worse. Most of the time the hole center shifted a bit more than with drilling it directly. If it should look nice i need a bit of luck too!
For me the work around feels exactly the same.
I can split the files. good for revision like things and with the right naming(
name_type) i can see what models have a drawing. But i can't filter / sort on model type when opening an existing file / or file browser. And i think i filter on model type way more that checking if every model has a drawing.
drmacro wrote: ↑Wed Jul 13, 2022 12:20 pm
There is no concrete way to discern
if a multiple file structure provides any benefit overall without having side by side data to compare. The benchmarks for such a comparison would need to be defined , what characteristic of each benchmark would represent beneficial, and then a version of FreeCAD produced to make the comparison.
Agree on this without optimization i don't expect speed improvement(from system view point). On user level (read searching to the requested file) it may improve speed.
