Ticket #4606 - Part Design Pad tool do not work in linux AppImage 24212 works in Windows 0.20 24489 (git)
Discussion thread for issue #4606: Part Design Pad tool do not work in linux AppImage 24212 works in Windows 0.20 24489 (git)
Re: Tiket #4606 - Part Design Pad tool do not work in linux AppImage 24212 works in Windows 0.20 24489 (git)
I guess this is related to ooct7.4 / occt7.5 differences?
I just tried with Windows using both OCC 7.5 and OCC 7.4 versions. Both worked without any problem.
Pad and Pocket obviously work with both OCC versions, since many users would complain otherwise.
Must be something else.
Gene
Gene
- alonso_jamm
I tried with the latest FreeCAD AppImage 24276 and 0.20 24495 and had the same problem with both versions. The AppImage is using OCC 7.4 and the 0.20 version is using OCC 7.5.
I found that this problem doesn't occur when I set the value of the diameter constraint of the big arc in "Sketch006RuuvinRunko" from 61mm to 61.3mm (by removing the expression). If I set the value of this diameter constraint to a smaller value than 61mm it will result in material being added in the inner region of the revolution but not on the outer region.
Also, instead of modifying "Sketch006RuuvinRunko" and using a custom pad direction instead does not produce this problem.
I just added a small value (0.01mm) in the x-direction. versions I used:
OS: Arch Linux (KDE//usr/share/wayland-sessions/plasmawayland)
Version: 0.19.24276 (Git) AppImage
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
and
Version: 0.20.24495 (Git)
Hash: 6317acc97ca1d8f02f763cc4d4be3795305d9b40
Python version: 3.9.2
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Qt version: 5.12.9
OCC version: 7.4.0
and
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I can confirm the problem here, looks like a so called coplanar issue.
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.4.0
- adrianinsaval
Re: Ticket #4606 - Part Design Pad tool do not work in linux AppImage 24212 works in Windows 0.20 24489 (git)
xposting my findings posted on github issue: confirmed the bug in many versions of freecad (0.19.4 0.20.0 and 0.21.29446) using occt 7.5.3 or 7.6.2 (blobfish), only version where it worked was 0.19.3 flatpak that used occt 7.3 so it could be a regression upstream. I also observed this weird behavior when changing the pad length on all the failing versions:
