It's basically just a stack - really. Until further notice, observed in this version/environment.
OS: Arch Linux (/usr/bin/startxfce4)
Version: 0.19.23141 (Git) AppImage
Hash: 0eba78d40096720f7a637a9a73c382a08b820bca
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
When zooming into my model with the mouse wheel, everything works up to a certain point. Then, visual zooming stops. FreeCAD still seems to take the mousewheel zooming into account internally (but not visually), because the longer I try, the longer it also takes to scroll the mousewheel in the opposite direction (to zoom out) to actually have some visual feedback again. UI is not blocked or anything.
Fun fact: sometimes - not reproducible (so far) - when I toggle active part so it's alone on the screen, further zooming does happen. But not always, r should I say "with 0.19.23141 in the minority of the cases now".
I did search the forums
https://forum.freecadweb.org/viewtopic.php?t=17207
https://forum.freecadweb.org/viewtopic.php?t=50231
but none of these seem applicable/a solution.
Tools > Edit Parameters - a desert
There are lots (read: the majority) of entries that actually do not contain any parameters. So the question is why show them at all?
e.g. Preferences: "AddOns" has some params, but then
AppImage, Bitmaps/Theme, Browser, DAGView, Dialog => nada
they are simply just in the way.
Expression, NaviCube, Macro/Macros, Plugins/parts_library etc. => nada
Maybe don't show it if it has no information value.
While we are at it, the "Parameter Editor" window has an inconsistent windows handle. See, if I call Edit > Preferences, I can actually close that window with the 'x'. Not so in the Parameter Editor, where I fullscreen the window. Every. Single. Time. You got me there.
Right mouse contextual menu - the Jester
Let's say you want to change the color of an object. What do you do? You right-click mouse, see "Appearance", click that, change the color.How about a little magic trick? I'm gonna make this pencil disappear...
Now you want to do the same with the next object. Naturally you right-click mouse, see ... nothing. Tadaa!
Compare its_there.jpg and its_gone.jpg attached.
That is the Houdini feature of FreeCAD. But there is a not-so-elegant workaround: You "simply" Toggle active part of some other object and voila! It's there again.
