Air Plane Design Workbench - discussion thread
johnwang
Re: Air Plane Design Workbench - discussion thread
Post by johnwang »
cool.
When switch to the wb, got this error:
08:52:50  No module named 'freecad.plot'
08:52:50  Traceback (most recent call last):
  File "<string>", line 61, in Initialize
  File "D:\FreeCAD_0.19.21937_x64_LP_12.1.6_PY3QT5-WinVS2015\Mod\FreeCAD_AirPlaneDesign\airPlanePanel.py", line 33, in <module>
    from airPlaneRib import WingRib, ViewProviderWingRib
  File "D:\FreeCAD_0.19.21937_x64_LP_12.1.6_PY3QT5-WinVS2015\Mod\FreeCAD_AirPlaneDesign\airPlaneRib.py", line 43, in <module>
    import freecad.plot.Plot as Plot
OS: Windows 10 (10.0)
Version: 0.19.21937 (Git)
Hash: 0de5a290113800dc5779a76d7e216bd882e0ed1e
Python version: 3.6.8
Qt version: 5.12.1
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
a179308
Post by a179308 »
johnwang wrote: Sat Jan 23, 2021 10:00 pm cool.
Qt version: 5.12.1
Hi
You need to install the plot workbench.(https://wiki.freecadweb.org/Plot_Module)
Fred
johnwang
Post by johnwang »
a179308 wrote: Sat Jan 23, 2021 10:19 pm You need to install the plot workbench.(https://wiki.freecadweb.org/Plot_Module)
Hi Fred,
My Addon Manager doesn't work. No List. Where could I download this Plot WB?
Since the Plot Workbench is a layer on top of matplotlib, could you use matplotlib directly whithout rely on another WB?
like:
		import matplotlib.pyplot as plt
Regard,
John
a179308
Post by a179308 »
Hi
You can find all workbenchs here https://github.com/FreeCAD/FreeCAD-addons
Fred
a179308
Post by a179308 »
johnwang wrote: Sat Jan 23, 2021 10:25 pm
Hi Fred,
like:
Regard,
John
Hi
Ok I will check if it possible.
Fred
johnwang
Post by johnwang »
This is a simple x-y plot Macro
x=[1,2,3]
Y=[2.5,3.4,6]
plt.xlabel('Month')
plt.plot(x,Y)
plt.ylabel('Count')
plt.title("x-y plot")
fig = plt.gcf()
fig.canvas.set_window_title('bjPlot')
plt.grid(True)
plt.show()
trijonb
Post by trijonb »
hi there,
I am new to FreeCad, having used things like ProEngineer and SW in the distant past. I have installed the AirPlaneDesign WB, and want to make a vertical strut i.e.
I'd like the profile in the X-Y and the span in the Z-direction.
My issue is, no matter what data I provide, (custom or built in, eg NACA 0012, both of which have profile point data in the XY coords), the profile is generated in the XZ and span / extrusion in the Y.
When i check the imported point data, Y is unpopulated, X / Z are the real coords (strange because in the Import window, data is correct).
Also, when trying to rotate around various axes, i get very strange results? Units in panel say deg but perhaps its radians?
any help appreciated, I am on latest Win10 release (0.19).hopefully no one else is having this issue and its something easily fixed my side.
tx in advance
TWrecks
Post by TWrecks »
Is this workbench supported in FreeCAD 0.20? I'm getting the error "No module named 'freecad.plot.Plot'" when I select the "Air Plane Design" workbench.
I have the "Plot Workbench" installed, but I noticed this thread references the "Plot Module" which now redirects to the "Plot Workbench" in the Wiki.
Tim
Post by Kunda1 »
johnwang
Post by johnwang »
TWrecks wrote: Tue Jun 28, 2022 2:11 am Is this workbench supported in FreeCAD 0.20? I'm getting the error "No module named 'freecad.plot.Plot'" when I select the "Air Plane Design" workbench.
Tim
I asked this last year. Now I have a quick fix, same as https://forum.freecadweb.org/viewtopic. ... 44#p599044
Find airPlaneRib.py, change:
to
#import freecad.plot.Plot as Plot
from FreeCAD.Plot import Plot
The first line is commented out.
You also need to install curvedshape WB.
No need to install "Plot Workbench".
Have fun.
John
