Curved Shapes Workbench
Re: Curved Shapes Workbench
I've got a CurveSegment twisted.
Have a look with my file.
- test1.FCStd
- (11.68 KiB) Downloaded 80 times
InterpolatedMiddle is on the wrong side this this file.
Must be like the red one.
Anyway, thanks to share your Wb. It's sound like fun.
Could be a step forward for surface design.
- test2.FCStd
- (26.43 KiB) Downloaded 77 times
- Capture.JPG (18.15 KiB) Viewed 3558 times
Hi GlouGlou,
in both cases we have the same problem: the current version of the workbench always tries to find a point between the starting point of one curve and the starting point of the other one. I have to find a way to move the starting points.
I have added two parameters to the InterpolatedMiddle and the Curved Segment tools: Twist and Reverse
If your result is twisted, you can play with these paremeters to get rid of the twist.
I have added a scripted flying wing to the workbench.
sorry. I fixed it.
Thanks to share it. look like promising.
Some troubles with CurvedArray. I made something wrong?
- Surface_1.FCStd
- (15.56 KiB) Downloaded 99 times
- shape_1.FCStd
- (13.54 KiB) Downloaded 90 times
- Wing_1.FCStd
- (29.72 KiB) Downloaded 107 times
I did some improvements to the CurvedArray algorithms. Please update the workbench.
@GlouGlou: your example designs work better now
Remember: The first curve that you select for CurvedArray creation will be the item that is swept and resized in the bounds of the other selected curves.
If you create a surface or solid and it looks weird, this may be caused by very small items at trhe start and end of the CurvedArray. In this case, enter values bigger than 0 for Start Offset and End Offset. This will create bigger start and end items located not at the very end.
Nice improvements!!!
just 2 lines here at the beginning and the end who want still joke.
- Capture.PNG (46.8 KiB) Viewed 3253 times
