Curved Shapes Workbench
christi
Re: Curved Shapes Workbench
Post by christi »
GlouGlou wrote: Thu Jun 24, 2021 9:14 pm maybe an option to give the size of hull for scale factor instead the bounding box of the whole hull curves could avoid that?
I think this will make my tool too complicated
miniellipse
Re: Curved Shapes Workbench python errors
Post by miniellipse »
I updated fcad on my mac and when I load an example file from the forum, I get this errors in report view:
10:18:40 Traceback (most recent call last):
File "/Users/ADMacMini/Library/Preferences/FreeCAD/Mod/CurvedShapes/CurvedArray.py", line 196, in onChanged
self.execute(fp)
File "/Users/ADMacMini/Library/Preferences/FreeCAD/Mod/CurvedShapes/CurvedArray.py", line 179, in execute
self.makeRibs(prop)
File "/Users/ADMacMini/Library/Preferences/FreeCAD/Mod/CurvedShapes/CurvedArray.py", line 93, in makeRibs
d = CurvedShapes.distribute(x / (sections - 1), obj.Distribution, obj.DistributionReverse)
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Distribution'
self.execute(fp)
self.makeRibs(prop)
self.execute(fp)
self.makeRibs(prop)
Any help is appreciated.
OS: macOS 10.16
Version: 0.19.24366 (Git)
Python version: 3.9.7
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.3
Locale: C/Default (C)
Sirius_2009-Wing.FCStd
(362.66 KiB) Downloaded 60 times
Vincent B
Post by Vincent B »
Could be like this or something looks like. :)
Sirius_2009-Wing_vb.FCStd
(262.41 KiB) Downloaded 61 times
miniellipse
Vincent B wrote: Mon Mar 28, 2022 5:34 pm Could be like this or something looks like. :)
Ha ha.. I thought by now, you would have finished this plane. I am trying to learn somethings but I upgraded my home computer to OSX Monterey and now I have issues with the Curves WB. I got these same errors when I opened your new Sirius_2009-Wing_vb file. I really think the system upgrade broke/changed some python things but I do not know how to fix. :x
Screen Shot 2022-03-28 at 8.16.55 PM.png (69.21 KiB) Viewed 3137 times
bntarc
Post by bntarc »
Thank you so much christi for the Notch Tool.
I have difficulties using it.
When I do the Notch the parts turn 90 degres............
Notch test Link before.FCStd
(4.78 KiB) Downloaded 55 times
Notch test Link after.FCStd
(10.11 KiB) Downloaded 54 times
Before Notch.png (7.78 KiB) Viewed 3039 times
After Notch.png (8.55 KiB) Viewed 3039 times
christi
Post by christi »
miniellipse wrote: Sat Mar 26, 2022 5:37 pm I updated fcad on my mac and when I load an example file from the forum, I get this errors in report view:
Your design was created with an older version of the CurvedShapes workbench. Delete and re-create the Curved Array parts to get them updated.
christi
Post by christi »
bntarc wrote: Mon Apr 04, 2022 8:14 pm Thank you so much christi for the Notch Tool.
It seems that the algorithm to find out the cut direction does not work. Since I have not found a solution for this, you can manually change the parameter Cut Direction in your design. Set Cut Direction to 0,0,1 for the first NotchConnector and 0,0,-1 for the second. Enter the z value first, because 0,0,0 will again evaluate to the wrong values.
christi
Post by christi »
I found a better solution for the CutDirection finding algorithm. Please update the workbench and try again.
Zivatar
Post by Zivatar »
christi wrote: Sun Apr 10, 2022 6:35 am
Hello Guys,
I am experiencing the same like miniellipse, but with a freshly updated system and .AppImage:
OS: openSUSE Leap 15.3 (GNOME/default)
Version: 0.20.28647 (Git) AppImage
Branch: (HEAD detached at 1c1743b)
Hash: 1c1743b67d209f2b6501de4f75645a33b69d1c31
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: Hungarian/Hungary (hu_HU)
Installed mods:
  * Plot
  * Curves 0.4.2
  * MeshRemodel 1.8919.0
  * fasteners 0.3.40
  * CurvedShapes 1.0.2
  * Silk -1861983584.0.0
  * sheetmetal 0.2.49
  * AirPlaneDesign 0.4.0
  * Assembly4 0.11.10
  * Manipulator 1.4.3
My design is this
Test2.FCStd
(14.92 KiB) Downloaded 54 times
, and the Report view says:
14:55:44  Traceback (most recent call last):
  File "/home/zivatarw/.local/share/FreeCAD/Mod/CurvedShapes/./CurvedArray.py", line 196, in onChanged
    self.execute(fp)
  File "/home/zivatarw/.local/share/FreeCAD/Mod/CurvedShapes/./CurvedArray.py", line 179, in execute
    self.makeRibs(prop)
  File "/home/zivatarw/.local/share/FreeCAD/Mod/CurvedShapes/./CurvedArray.py", line 114, in makeRibs
    if (obj.Surface or obj.Solid) and obj.Items > 1:
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Surface'
14:55:44  16Standard_Failure Need at least two vertices, edges or wires to create loft face
14:55:44  Creation of surface is not possible !
14:55:44  <Part> ViewProviderExt.cpp(1268): Cannot compute Inventor representation for the shape of Test2#CurvedArray: Bnd_Box is void
Can anyone help what could be the problem? The CurvedArray object looks like no problem at all, but I cant use the model for further work.
Thanks,
Zivatar
Zivatar
Post by Zivatar »
Meanwhile I carried out a different test:
Symptoms are the same on a different fresh system.
KR,
Zivatar
