Fasteners workbench based on screw-maker
ppemawm
Re: Fasteners workbench based on screw-maker
Post by ppemawm »
felixcollins wrote: Tue Jul 26, 2022 9:55 pm Is it possible to explode/unlock the item to allow it to be edited?
Import the .step file and drag/drop it into an Assembly4 Body which creates a BaseFeature that you can modify with PartDesign to your heart's content.
"It is a poor workman who blames his tools..." ;)
RussG
Confused by Fasteners WB Proprties
Post by RussG »
OS: macOS 10.16
Version: 0.20.29177 (Git)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
  * fasteners 0.3.50
I making a standard c-clamp for 3D printing. I created a threaded rod using the Fasteners WB. I chose a UNC threaded rod. In the Parameters section of the Property window there is a <value> property setting for the diameter of the rod. I selected 1/2". But there is also a <diameter Custom> property which is a selectable <value> in mm only, and both diameters can be set independently. (see screenshot). So, how can there be two diameters, <diameter> and <diameter Custom> both of which can selected at the same time and in different sizes and systems as well? I didn't find an explanation in the Fasterners WB wiki. Did I miss something? What do I need to know here?
Also, in making a threaded hole in the C portion of the c-clamp through which the threaded rod will run, the Hole feature in Part Design allows for Class selection for the threads of 1A, 1B and 1C. I found info about these classes at a very nice page from Fastenal at <https://www.fastenal.com/content/feds/p ... Design.pdf> for anyone interested in that. I understand the thread classes as having to do with the tolerances of the threads. So here my problem is that while I can pick a class of thread for the hole in Part Design the Fasteners WB doesn't offer that for threaded rods but rather just says "standard coarse threads" when hovering over the threaded rod icon. So, it seems there is no way to match the thread class for the male threads of the threaded rod and the female threads of the hole. Here too, what do I need to know?
Thanks so much everyone!
diamerer Custom.jpg (127.48 KiB) Viewed 2075 times
Reason: Merged this post in to the main FastenerWB thread
shaise
Post by shaise »
Hi All
The Fastener Workbench has undergone a major refactoring:
- Screw creation was split to separate files per fastener type.
- Lots of code duplication cleaned.
- Adding new fasteners is easier now.
- All fasteners now support real thread (including PEMs and PCB fasteners
The Contributing.md was updated accordingly
Naturally this overhaul might introduce new bugs and it is hard to test all possible scenarios. If you encounter bugs (specially backward compatibility) please let me know asap here in the forum, or  raise an issue on the GitHub repository https://github.com/shaise/FreeCAD_FastenersWB.
Thanks
Bance
Post by Bance »
Well done @shaise !
Thanks for this great WB. :D
obelisk79
Post by obelisk79 »
I love this workbench, thanks so much for the continued effort to improve it!
KurtF
Re: Confused by Fasteners WB Proprties
Post by KurtF »
RussG wrote: Wed Aug 10, 2022 12:12 am So here my problem is that while I can pick a class of thread for the hole in Part Design the Fasteners WB doesn't offer that for threaded rods but rather just says "standard coarse threads" when hovering over the threaded rod icon. So, it seems there is no way to match the thread class for the male threads of the threaded rod and the female threads of the hole. Here too, what do I need to know?
Hi Russ. I posted an add-on to this WB months ago, which I think meets your needs. Tolerance classes (ISO) are specified the same way for male and female threads. Ditto for diameters.
KurtF wrote: Sun Jun 12, 2022 12:48 am I just posted in Macros: ThreadMaker final release. https://forum.freecadweb.org/viewtopic.php?f=22&t=69355 I think you'll like it for generating ISO 261 Metric threads, or Custom free-hand dimensions.
May whatever Higher Power you believe in bless the Ukrainians. They are a decent people who never hurt anybody.
shaise
Post by shaise »
RussG wrote: Wed Aug 10, 2022 12:12 am So, how can there be two diameters, <diameter> and <diameter Custom> both of which can selected at the same time and in different sizes and systems as well? I didn't find an explanation in the Fasterners WB wiki. Did I miss something? What do I need to know here?
As soon as you select and change <diameter Custom>, <diameter> will change from a value to "Custom"
Same when you select a different <diameter>, it will automatically update <diameter Custom> to be the same (but in mm)
In short:
if <diameter> shows any value, this value will be taken. If you set <diameter> to "Custom", <diameter Custom> will be taken instead.
rynn
Post by rynn »
shaise wrote: Mon Aug 22, 2022 8:01 am Naturally this overhaul might introduce new bugs and it is hard to test all possible scenarios. If you encounter bugs (specially backward compatibility) please let me know asap here in the forum, or  raise an issue on the GitHub repository https://github.com/shaise/FreeCAD_FastenersWB.
I like the refactoring, thanks a lot.
(issue: https://github.com/shaise/FreeCAD_Faste ... issues/163)
Post by Kunda1 »
@shaise thank you so much for your refactoring work on Fasteners! Paves the way for more contributions now that you've simplified the fasteners adding configuration. +1
KurtF
Post by KurtF »
Kunda1 wrote: Mon Aug 22, 2022 5:51 pm @shaise thank you so much for your refactoring work on Fasteners! Paves the way for more contributions now that you've simplified the fasteners adding configuration. +1
Hello, Shai. First, want to echo that from Kunda! I finally got a chance to look at it, but unfortunately it threw an error on my first nut. My FC version is a little old, and I wouldn't be surprised if the error disappeared by upgrading my FC. But you did say you wanted info on back compatibility, so here's the details. And thanks again for all the work you put into this!
Edit Update: Ok cancel this error report. I restarted FC 2 more times and now I cannot reproduce any of it. But I'll leave the details just in case you want to see it.
OS: Windows 10 (10.0)
Version: 0.20.28671 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
  * fasteners 0.4.3
Report View showing 2 clicks on nut buttons:
11:57:58  Save AutoRecovery file: Needed time: 19ms
11:58:15  Get diams for type:ISO4035
11:58:15  Running the Python command 'FSISO4035' failed:
  File "C:\Users\kurtf\AppData\Roaming\FreeCAD\Mod\fasteners\.\FastenersCmd.py", line 538, in Activated
    FSScrewObject(a, self.Type, selObj)
  File "C:\Users\kurtf\AppData\Roaming\FreeCAD\Mod\fasteners\.\FastenersCmd.py", line 170, in __init__
    self.VerifyMissingAttrs(obj, type)
  File "C:\Users\kurtf\AppData\Roaming\FreeCAD\Mod\fasteners\.\FastenersCmd.py", line 236, in VerifyMissingAttrs
    diameters = screwMaker.GetAllDiams(type)
  File "C:\Users\kurtf\AppData\Roaming\FreeCAD\Mod\fasteners\.\ScrewMaker.py", line 305, in GetAllDiams
    return sorted(FsData[type + "def"], key=FastenerBase.DiaStr2Num)  # ***
  File "C:\Users\kurtf\AppData\Roaming\FreeCAD\Mod\fasteners\.\FastenerBase.py", line 222, in DiaStr2Num
    return FsData["DiaList"][DiaStr][0]
name 'FsData' is not definedSave AutoRecovery file: Needed time: 18ms
12:03:58  Save AutoRecovery file: Needed time: 0ms
12:05:06  Get diams for type:ASMEB18.2.2.1A
12:05:06  Running the Python command 'FSASMEB18.2.2.1A' failed:
name 'FsData' is not definedSave AutoRecovery file: Needed time: 19ms
12:09:58  Save AutoRecovery file: Needed time: 0ms
Error occurs on both old document with fasteners from prior FW version; and on brand new empty document. Let me know if I can get you any more detail.
On a separate matter, what do you think about merging my macro code for creating mated male/female thread shafts/inserts? I feel it is the one thing missing from FW, the ability to create mating threads of almost any length or size (or pitch, tolerance), for projects like the C clamp above. I'm interested to know your thoughts.
