Fasteners workbench based on screw-maker
Re: Fasteners workbench based on screw-maker
@mario52
Try to download original FastenersCmd.py and replace it on youre installed workbench:
https://github.com/shaise/FreeCAD_Faste ... nersCmd.py
After that, everything should work.
Hi
not work , only my modification work fine for all linguage see my first post https://forum.freecadweb.org/viewtopic. ... 50#p645350
mario
mario
I have downloaded the latest version of Fasteners. And added the translation files.
I can't reproduce the error you are talking about. I have everything perfectly translated and working.
A long dash does not affect the translation in any way. And it shouldn't affect.
Perhaps should not make a Pull-request until the reason is found.
Hi
translate only with my modifications
mario
not translate
OS: Windows 10 Version 2009
Version: 0.21.0.31513 (Git)
Hash: b2ab8edba4bfd71681e639f8c3f1105066bed4c7
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: French/Mars(fr_MA)
A little bit off-topic from the posts above: the thickness of M6 Washers - ISO7092 / DIN433 seems wrong to me.
It should be 1.6 mm, not 1.8 mm.
I checked online on various sources.
Seems to be:
1.4 mm min
1.6 mm nominal
1.8 mm max
1.4 mm min
1.6 mm nominal
1.8 mm max
I use the DIN433/ISO7092 quite often and I never saw an M6 washer with 1.8 mm of thickness...
Look here:
https://www.schrauben-lexikon.de/norm/ISO_7092.asp
As you can see here, the official thickness are:
- nominal = 1.6 mm
- min = 1.4 mm
- max = 1.8 mm
Look here:
- nominal = 1.6 mm
- min = 1.4 mm
- max = 1.8 mm
Hi
ok
C:\Users\YourName\AppData\Roaming\FreeCAD\Mod\FastenersWB\FsData\iso7092def.csv
("h" = 1.6 and "h_max" = 1.8 as https://www.fasteners.eu/de/standards/ISO/7092/)
mario
ok
"ISO7092def"
"Dia","d1_min","d2_max","h","h_max"
"M1.6",1.7,3.5,0.3,0.35
"M2",2.2,4.5,0.3,0.35
"M2.5",2.7,5.0,0.5,0.55
"M3",3.2,6.0,0.5,0.55
"M4",4.3,8.0,0.5,0.55
"M5",5.3,9.0,1.0,1.1
"M6",6.4,11.0,1.6,1.8
"M8",8.4,15.0,1.6,1.8
"M10",10.5,18.0,1.6,1.8
"M12",13.0,20.0,2.0,2.2
"M16",17.0,28.0,2.5,2.7
"M20",21.0,34.0,3.0,3.3
"M24",25.0,39.0,4.0,4.3
"M30",31.0,50.0,4.0,4.3
"M36",37.0,60.0,5.0,5.6
You are correct, It is a bug that happened in one of the latest changes causing h_max to be used instead of h. It is fixed now.Giulio Buccini wrote: ↑Fri Jan 13, 2023 2:15 pm A little bit off-topic from the posts above: the thickness of M6 Washers - ISO7092 / DIN433 seems wrong to me.
