Techdraw in Link, dimensions don't position with graphic
Report observations made with the new Toponaming branch.
rich61
Post by rich61 »
This occurs in the RT link branch version for me.
TechDraw Bug?: The dimensions are not attached or coupled to the view after reloading. When you move the graphic, the dimensions do not follow.
To test, New Session: Create a cylinder 1" diameter, pad to anything
-- Create techdraw TOP view, dimension the circle diameter = 1"
-- Drag the view near the bottom left of the sheet, the dimension follows ( works correctly )
-- Save & Close
-- Reload same file
-- Drag view, dimensions do not follow (it also have a crazy zoom initially)
-- Set view property X,Y to 0,0 and the dimension is aligned with the graphic when it is at 0,0 - the dimensions are stuck at 0,0
-- So, the dimension lines are not using the X,Y properties as they should be
Topo and Master with the same file are able to properly move views created in RT, even when RT does not.
My installation is on Ubuntu 22.04 and snap but one other user on Windows has the same issue.
Is anyone else having this issue ?
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 2022.1031.14555 (Git shallow)
Branch: (HEAD detached at 2022.10.31-edge)
Hash: f296baf2593a4eb96b87a5b4e47ebedae0e39c61
Python version: 3.8.10
Qt version: 5.15.5
Coin version: 4.0.1
OCC version: 7.6.3
mwlandolsi
Re: Techdraw in Link, dimensions don't position with graphic
Post by mwlandolsi »
Thanks for opening this thread. I have the same problem with :
OS: Linux Mint 21 (X-Cinnamon/cinnamon)
Version: 2022.1112.26244 +5306 (Git) AppImage
Branch: LinkDaily
Hash: c64e4a49244a1c0ce9fd6455d18aa919d0db9c80
Python version: 3.10.6
Qt version: 5.15.4
Coin version: 4.0.1
OCC version: 7.6.3
After saving, closing and opening a drawing, the dimensions do not remain in position.
Screenshot from 2022-11-19 05-34-46.png (183.96 KiB) Viewed 1254 times
rich61
Post by rich61 »
Thanks for posting that. It is now reported by just 3 people. Must be a bug that affects only a few.
If you select the view that those dimensions are for, and in the Data Property - Base, set X and Y to zero, then the dimensions will match the view.
The set of dimensions are stuck at (0,0). I installed the appimage release 20220704, techdraw works in that release.
rich61
Post by rich61 »
This issue was fixed in RT Version 2022.1128
Closed
