asm3 spamming console and comboview
Report observations made with the new Toponaming branch.
freman
Post by freman »
just came back to asm3 on master and dragging a Part into the Assembly object in comboview is spamming console and reportview with traceback errors.
It seems that every time the drap op passes over a target where it cannot drop , instead of just changing the cursor it is making a mess.
Someone may need to look at this.
Cheers.
  File "~/.FreeCAD/Mod/FreeCAD_assembly3/freecad/asm3/assembly.py", line 4605, in canDropObjectEx
    return partGroup.canDropObject(obj,owner,subname)
<class 'TypeError'>: argument 2 must be App.DocumentObject, not None
OS: Fedora Linux 35 (Thirty Five) (LXQt//usr/share/xsessions/lxqt)
Version: 0.21.30265 (Git)
Hash: c35244e74f326a04c5bcab31e984742db582ac78
Python 3.10.6, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.3, OCC 7.5.0
Installed mods:
  * FreeCAD_Assembly4 0.11.10
  * FreeCAD_assembly3
adrianinsaval
Re: asm3 spamming console and comboview
Post by adrianinsaval »
is your assembly3 up to date?
freman
Post by freman »
adrianinsaval
please don't double post, also here you posted a question about master branch on the link branch subforum
freman
Post by freman »
You will see the first reply I got on that thread was to tell me to post here !
Probably posting in the dedicated thread you will receive more "focused answers".
adrianinsaval
well @onekk was wrong there unfortunately, sadly many people see asm3 and directly assume linkbranch while you are clearly using master branch. The assembly forum was the right place to post.
onekk
Post by onekk »
freman wrote: Wed Sep 21, 2022 3:30 am ...
Sorry for the nuisance.
Thanks @adrianinsaval for the correction, I will amend the post to avoid future misunderstandings.
Regards
Carlo D.
- Various other stuffs.
