[Bug] PartDesign Revolution runs into problems in new release, does fine in older ones
Report observations made with the new Toponaming branch.
pathfinder
Post by pathfinder »
I just noticed this. If I try a simple revolution like the one in the sample file, it fails with the error message
gp_Dir::Crossed() - result vector has zero norm
I tried rotating around the sketch axis, Y-axis and (as I usually do) around the sketches edge itself, all of which failed.
The version in question:
OS: Arch Linux (XFCE/xfce)
Version: 2022.704.26244 +4971 (Git) AppImage
Branch: LinkDaily
Hash: a87320cc64699a8e4226bad2e9b37ac3a1296ab9
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
An earlier version I happened to still have has no issue whatsoever to do the rotation:
Version: 2022.430.26244 +4758 (Git) AppImage
Branch: LinkDaily
Hash: b024b876480a533018fdc702145e9e38f8c54ba6
Python version: 3.9.12
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
I tried the newest* version of vanilla FC and it worked with it, which is why I'm posting it here and not in the main forum.
*haven't checked whether there's a newer one out, but I downloaded it two days ago
for_forum.FCStd
(10.35 KiB) Downloaded 34 times
Founder
Re: [Bug?] PartDesign Revolution runs into problems in new release, does fine in older ones
Post by wmayer »
With the official FreeCAD version it works without problems for every axis but Z axis.
Branch: LinkDaily
Might be a bug in this branch.
pathfinder
wmayer wrote: Sun Jul 24, 2022 6:14 am With the official FreeCAD version it works without problems for every axis but Z axis.
Branch: LinkDaily
Yeah, I have the same results here.
It won't rotate around the Z-axis because the sketch is on the XY plane, so a rotation around the Z-axis would rotate the sketch along its plane; so this is expected/desired behavior.
Seems to be a bug indeed. I'm not good with Github, but if someone else is and feels like it, it would be great if someone made a bug report.
Founder
Re: [Bug] PartDesign Revolution runs into problems in new release, does fine in older ones
Post by wmayer »
pathfinder wrote: Sun Jul 24, 2022 9:38 pm It won't rotate around the Z-axis because the sketch is on the XY plane, so a rotation around the Z-axis would rotate the sketch along its plane; so this is expected/desired behavior.
Of course.
pathfinder wrote: Sun Jul 24, 2022 9:38 pm Seems to be a bug indeed. I'm not good with Github, but if someone else is and feels like it, it would be great if someone made a bug report.
As said this seems to be a bug in the Link branch and an error report should be created at https://github.com/realthunder/FreeCAD
