(SOLVED) Snaping point is not displayed
Report observations made with the new Toponaming branch.
realthunder
Re: Snaping point is not displayed
Post by realthunder »
The issue is mostly about the questionable choice of white color for the snap point. In your OP, you are trying to show the snapping point of the moving object, which is a rare case I'd say. I expect in most cases, the user would want to snap to other objects, hence without selection highlight, make it easy to see the snap point. And I've tested that it works about the same as the upstream master. It works better if you enable both selection on top and preselection on top.
Peek 2022-06-26 08-39.gif (261.3 KiB) Viewed 1426 times
With the LinkDaily branch (the one you just installed), you can also try the experimental render cache, which works better in all cases.
Peek 2022-06-26 08-39-2.gif (471.91 KiB) Viewed 1426 times
Roy_043
Post by Roy_043 »
realthunder wrote: Sun Jun 26, 2022 12:47 am the questionable choice of white color for the snap point.
FYI that color can be changed in the preferences. See Draft_Snap#Preferences.
bambuko
Post by bambuko »
I must be doing something wrong again .... :mrgreen:
I worked out the snap colour change (same as? @Roy_043 ):
Selection settings were (same as? @realthunder ):
and yet... when I try to select, snapping point (@thomas-neemann) is not displayed??
Screenshot from 2022-06-26 09.56.32.png (167.65 KiB) Viewed 1353 times
Any ideas, please, what am I doing wrong?
OS: Ubuntu Core 20 (Pantheon/pantheon)
Version: 2022.625.14555 (Git shallow)
Branch: (HEAD detached at 2022.06.25-edge)
Hash: 0191f4edf1b19bf52124a4be654074b5cc035645
Python version: 3.8.10
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.6.2
I am using Link branch and Assembly3
you can also download ... and try it here
excellent Assembly3 tutorials here
realthunder
bambuko wrote: Sun Jun 26, 2022 9:04 am Any ideas, please, what am I doing wrong?
Can you please send me your user settings? Tools -> Edit parameters -> Export.
bambuko
Post by bambuko »
realthunder wrote: Sun Jun 26, 2022 9:10 am ...send me your user settings?
Thank you - I have sent you a PM
bambuko
Post by bambuko »
possibly a clue?
10:36:58  Running the Python command 'Draft_Snap_Center' failed:
  File "/tmp/.mount_FreeCAunleRl/usr/Mod/Draft/draftguitools/gui_snaps.py", line 385, in Activated
    sync_snap_statusbar_button("Draft_Snap_Center_Statusbutton", status)
  File "/tmp/.mount_FreeCAunleRl/usr/Mod/Draft/draftguitools/gui_snaps.py", line 89, in sync_snap_statusbar_button
    for a in ssb.menu().actions() + ssw.children()[-6:]:
local variable 'ssb' referenced before assignmentPick end point
when using:
OS: elementary OS 6.1 Jólnir (Pantheon/pantheon)
Version: 2022.430.26244 +4758 (Git) AppImage
Branch: LinkDaily
Hash: b024b876480a533018fdc702145e9e38f8c54ba6
Python version: 3.9.12
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
and
10:39:39  Running the Python command 'Draft_Snap_Center' failed:
  File "/snap/freecad-realthunder/47/usr/Mod/Draft/draftguitools/gui_snaps.py", line 385, in Activated
  File "/snap/freecad-realthunder/47/usr/Mod/Draft/draftguitools/gui_snaps.py", line 89, in sync_snap_statusbar_button
local variable 'ssb' referenced before assignmentRunning the Python command 'Draft_Snap_Center' failed:
when using:
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.6.2
thomas-neemann
Post by thomas-neemann »
realthunder wrote: Sun Jun 26, 2022 12:47 am ...
it works now, thank you very much
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 2022.704.28821 (Git) AppImage
Branch: LinkStage3
Hash: c83a0368027dcdb972bfb3e0a00fbf9c26536fcd
Python version: 3.9.13
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
