Sketcher Bug?
Report observations made with the new Toponaming branch.
Outsourced
Sketcher Bug?
Post by Outsourced »
OS: Windows 10 Version 2009
Version: 2022.407.28576 (Git)
Branch: LinkStage3
Hash: 599f7663af69d3dbd77063e834b12f26da513b2d
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Hello FC.
Please find file included @ https://drive.google.com/file/d/1Z_jVQe ... sp=sharing
Hopefully your opening the file now & cascading the spreadsheet with the Path_01, Split_i0, Oval_Pass, Path_002 &Path_003 visible.
Spreadsheet: Angle of Cut:- is ~55, + or - at 5 degrees and it will work all the way down to 1 degree, however if you work your way back up also at 5 degree increments the sketch Path_002 & Path_003 with start to fail about 70 degrees ( at this point ctl Z and save as another name. - But Im sure you know that. )
I am getting a warning; 11:37:24 <App> GeoFeatureGroupExtension.cpp(581): LS3407_Item_11_07_06_22B#Sketch005.ExternalGeometry(links to LS3407_Item_11_07_06_22B#Import001) is out of scope:<global> vs. LS3407_Item_11_07_06_22B#Body001.
It shouldn't be ! the body can be extended in the SS to any desired length it still fails.
Kind Regards
Mr Hippo
Re: Sketcher Bug?
Moved from Open discussion forum.
