Named dimension related bug
Report observations made with the new Toponaming branch.
llll
Post by llll »
First error is clear to see. Thinks "CirclePos" constraint is "A1" constraint... A restart solved the problem. Had to restart twice in a day so not that uncommon an error.
Second error I'm assuming is related is where there were 2 length dimensions. Both linked to the same spreadsheet cell B3 value. One dimension had a name "L1" -- left over from earlier versions. This I assume is what was causing an error where updating the cell "broke" the sketch and saw this error. Updating B3 didn't work.
No it's couldn't recreate the error in another document with same sketch.
Think error was introduced in Linkdaily and error persists in main branch versions.
OS: Windows 10 Version 2009
Version: 2022.430.28641 (Git)
Branch: LinkStage3
Hash: a77045488092c24ece25d63c91f362cbd2181d36
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English
adrianinsaval
Re: Named dimension related bug
Post by adrianinsaval »
File? This type of things simple cannot be verified or debugged without an example file or clear instructions to reproduce.
adrianinsaval wrote: Tue May 31, 2022 9:12 pm File? This type of things simple cannot be verified or debugged without an example file or clear instructions to reproduce.
May I correct you? "cannot be verified or debugged without an example file AND clear instructions to reproduce".
flachyjoe
Post by flachyjoe »
I had this bug too :
  1. Create a sketch with
    • a dimension depending a named one in the same sketch
    • some geometric constraints
  2. delete a constraint and create a new one
  3. -> Expression switch from the unamed dimension to the named one and create a cyclic dependency
Replace equality by parallelism cause the bug
Capture d’écran_2022-06-02_23-32-21.png (15.13 KiB) Viewed 710 times
sketch_bug.FCStd
(4.29 KiB) Downloaded 35 times
KO:
OS: Ubuntu Core 20 (XFCE/xubuntu)
Version: 2022.531.14555 (Git shallow)
Branch: (HEAD detached at 2022.05.31-edge)
Hash: 36367cecc18492fec00ee01ecb2214c79a326f76
Python version: 3.8.10
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.6.2
Locale: French/France (fr_FR)
OK:
OS: Ubuntu 22.04 LTS (XFCE/xubuntu)
Version: 0.20.
Branch: unknown
Hash: 3f04bf7b4d99723809d04237002496e88aa26ed3
Python 3.10.4, Qt 5.15.3, Coin 4.0.0, OCC 7.5.1
- Flachy Joe -
