Named dimension related bug
Posted: Tue May 31, 2022 5:14 am
First error is clear to see. Thinks "CirclePos" constraint is "A1" constraint... A restart solved the problem. Had to restart twice in a day so not that uncommon an error.
Second error I'm assuming is related is where there were 2 length dimensions. Both linked to the same spreadsheet cell B3 value. One dimension had a name "L1" -- left over from earlier versions. This I assume is what was causing an error where updating the cell "broke" the sketch and saw this error. Updating B3 didn't work. No it's couldn't recreate the error in another document with same sketch.
Think error was introduced in Linkdaily and error persists in main branch versions.
OS: Windows 10 Version 2009
Version: 2022.430.28641 (Git)
Branch: LinkStage3
Hash: a77045488092c24ece25d63c91f362cbd2181d36
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English
