Collection of differences between original master version and realthunder
Report observations made with the new Toponaming branch.
Roy_043
Re: Collection of differences between original master version and realthunder
Post by Roy_043 »
The extension is ".e57". But thanks for mentioning this. It reminds me I have to check Import_Export.
thomas-neemann
Post by thomas-neemann »
Roy_043 wrote: Fri May 06, 2022 12:51 pm The extension is ".e57". But thanks for mentioning this. It reminds me I have to check Import_Export.
thanks, added it
ich biete freecad online-support an, als mini-job
VHS Freecad Webseminare Herbst 2022
https://www.vhs-lingen.de/programm/beru ... 011#inhalt
https://www.vhs-lingen.de/programm/beru ... 012#inhalt
thomas-neemann
if the selectability is disabled for a sketch, it will be displayed in realthudunder
thomas-neemann
in realthunder you can e.g. transform sketch lines for kinematic operations (robot simulation).
2026.FCStd
(7.65 KiB) Downloaded 7 times
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 2022.430.26244 +4758 (Git) AppImage
Branch: LinkDaily
Hash: b024b876480a533018fdc702145e9e38f8c54ba6
Python version: 3.9.12
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.3
thomas-neemann
in the master you can display the ids of the sketch elements.
if you could edit that, you could replace sketch elements (e.g. spline with arc) like in solid works and avoid a topo.. problem.
I can't edit the name, is that possible in freecad?
Version: 0.20.29045 (Git) AppImage
Branch: (HEAD detached at bbc47e7)
Hash: bbc47e75c6836410a53518917cd5710ec89c7018
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
I'm not aware of a possibility to rename these. And I don't see how renaming would fix any TNP issues.
thomas-neemann
chrisb wrote: Thu Jun 09, 2022 7:44 am .... I don't see how renaming would fix any TNP issues.
here is an example
https://www.youtube.com/watch?v=fK4aQm2dGno
phpBB [video]
Solidworks has a different approach to naming their entities, so they don't change their numbering inadvertently. Fixing this for FreeCAD is what realthunder's work is all about.
thomas-neemann
chrisb wrote: Thu Jun 09, 2022 9:15 am ...
ok, the way the programs work may be different. but no algorithm can find out which sketch element has been replaced by another one. I find the workflow from solidworks useful
thomas-neemann
draft snap has problems detecting inner edges. realthunder recognizes inner points, so that you can create a line with curves.
from this you can fade in and out with e.g. so create a line.
in the master i can't select the points. does anyone know a possibility (except wireframe)?
Version: 0.20.29177 (Git) AppImage
Branch: (HEAD detached at 0.20)
Hash: 68e337670e227889217652ddac593c93b5e8dc94
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * InventorLoader 1.3.0
  * Curves 0.5.0
OS: Ubuntu Core 20 (XFCE/xubuntu)
Version: 2022.630.14555 (Git shallow)
Branch: (HEAD detached at 2022.06.30-edge)
Hash: 1117c16f6320aa4372fe6d76a734d8f4c3f94741
Python version: 3.8.10
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.6.2
edit
I found a solution. Draft shapebinder
