Troubleshooting appimage build
This subforum is specifically to discuss packaging issues on different platforms (windows, mac, linux), and using different packaging systems (conda, etc...)
jnxd
Post by jnxd »
So I'm trying to build an appimage following the instructions here: https://docs.appimage.org/packaging-gui ... aries.html.
However, when running
make install -DESTDIR=AppDir
.../linuxdeploy-x86_64.AppImage --appdir AppDir
I get an error:
-- Deploying dependencies for existing files in AppDir --
Deploying dependencies for ELF file AppDir/usr/bin/FreeCADCmd
ERROR: Could not find dependency: libFreeCADApp.so
ERROR: Failed to deploy dependencies for existing files
The result is slightly better when running
cmake . -DCMAKE_INSTALL_PREFIX=/path/to/freecad-install/usr/
make install
.../linuxdeploy-x86_64.AppImage --appdir /path/to/freecad-install/
But that still halts at
ERROR: Could not find dependency: Import.so
Any help would be appreciated.
My latest (or last) project: B-spline Construction Project.
Re: Troubleshooting appimage build
Post by Kunda1 »
you may want to ping looo on this
jnxd
Post by jnxd »
Hi @looo, tagging on Kunda's suggestion. Do you have any idea what might be happening?
adrianinsaval
Post by adrianinsaval »
I think looo doesn't follow this procedure so I don't know if he would be of much help
jnxd
Post by jnxd »
adrianinsaval wrote: Mon Oct 17, 2022 1:12 pm I think looo doesn't follow this procedure so I don't know if he would be of much help
If he can get me a step by step process that works for him, I'd be fine with that. (probably) unless that involves downloading a large amount of dependencies.
onekk
Post by onekk »
jnxd wrote: Mon Oct 17, 2022 1:35 pm
I think that @looo has published somewhere the script he uses to make the Appimage:
https://github.com/FreeCAD/FreeCAD-Bundle
Regards
Carlo D.
- Various other stuffs.
