conda, osx-arm64, occt7.6
looo
Re: conda, osx-arm64, occt7.6
Post by looo »
edwilliams16 wrote: Sun Aug 14, 2022 6:30 pm I'm not sure that this is the right thread, but the Mac package is missing FreeCAD.Base.ProgressIndicator, as used in Curves|GordonSurface
>>> FreeCAD.Base.ProgressIndicator()
TypeError: cannot create 'N4Base19ProgressIndicatorPyE' instances
OS: macOS High Sierra (10.13)
Version: 0.21.29971 (Git)
Hash: 29197f503dc8c802cd82c968d16f5e1356365bda
Locale: C/Default (C)
Installed mods:
  * Curves 0.5.4
  * DynamicData 2.46.0
  * fasteners 0.3.51
  * fcgear 1.0.0
  * GDML 1.8.0
  * Help 1.0.3
  * lattice2 1.0.0
  * MeshRemodel 1.8919.0
  * toSketch
It works on other platforms I have tried.
This fails for me in both systems (osx64 / osx-arm64). Maybe a qt5.15 /conda issue?
edwilliams16
Post by edwilliams16 »
@looo https://forum.freecadweb.org/viewtopic. ... yE#p461571 makes me think this has been lurking for a while. It seems FEM and Curves use the ProgressBar. Detailed version info has been absent in the reports I have found.
looo
Post by looo »
no issue with:
OS: Ubuntu 22.04 LTS (ubuntu:GNOME/ubuntu)
Version: 0.21.30265 (Git)
Hash: c35244e74f326a04c5bcab31e984742db582ac78
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
Locale: German/Austria (de_AT)
Installed mods:
  * Assembly3 0.11.3
OS: Windows 10 Version 2009
Installed mods:
  * Plot
also not working with:
OS: macOS 10.16
Version: 0.20.29177 (Git)
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * ThreadProfile 1.81.0
  * PieMenu
  * fasteners 0.3.44
  * Assembly4 0.12.0
  * Assembly3 0.11.3
looo
Post by looo »
I am still trying to cross-compile freecad. Not a big goal, but it would be nice to automate this process. Currently it fails with:
CMake Error at /Users/runner/miniforge3/conda-bld/freecad_1662619804597/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_p/lib/cmake/vtk-9.1/VTKPython-targets.cmake:428 (message):
  The imported target "VTK::vtkCommonCorePython" references the file
     "/Users/runner/miniforge3/conda-bld/freecad_1662619804597/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_p/lib/python3.10/site-packages/vtkmodules/vtkCommonCore.so"
  but this file does not exist.  Possible reasons include:
If anyone has an idea, feel free to give me a hint.
oursland
Post by oursland »
HI @looo, I'm currently trying to bring up a macOS ARM64 build using conda. I've had some success in building, however there's some weird runtime behavior that I'm still debugging. My progress is documented in this forum thread: viewtopic.php?t=76777&start=10
I have also made a PR to make netgen-feedstock build for macOS ARM64.
Ideally, once this work is completed and determined to be suitably functional, I'd like to assist in getting macOS ARM64 into the matrix of weekly builds.
chennes
Post by chennes »
I'm fighting with Netgen on my ARM machine today -- nothing architecture-specific, I don't think. I'm trying to use Netgen 6.2.2105, which clearly requires C++17 standard, but the CMake script is falling into the older, C++14-required branch. It seems to be trying to use a variable called "NETGEN_VERSION_62_2004", but that (very specific!) thing does not exist, at least on my installation. I have the more normal versions strings, however: does anyone know why this isn't using CMakes standard version comparison operations?
Chris Hennes
Pioneer Library System
oursland
Post by oursland »
@chennes Is this with the conda build environment? @looo informed me and I confirmed that netgen is included in smesh conda package and does not require the netgen package to be explicitly brought in and built against: https://github.com/conda-forge/netgen-f ... 1483762349.
JohnOCFII
Post by JohnOCFII »
oursland wrote: Mon Apr 17, 2023 12:51 am @chennes Is this with the conda build environment?
With these build instructions so close to what @looo is using for the weekly builds, it seems the Conda Build instructions from @oursland are a really clean way to go. I've had very good luck with them on my Mac.
https://github.com/oursland/FreeCAD-Build-Notes
