Page 2 of 2
Re: Snap channels for testing PRs (fixes/features)
Posted: Thu Mar 31, 2022 2:15 pm
by adrianinsaval
would the syntax mentioned here work:
https://docs.github.com/en/pull-request ... ts-locally
git fetch origin pull/ID/head:BRANCHNAME
What's their policy for cpu time? is it possible to run CI with snaps? Kunda can you try making a testing snap for the TN PR for example?
git commit 74f6710fb40f4eb02948255e50ab177a1637c6d9
Posted: Thu Mar 31, 2022 3:37 pm
by ppd
adrianinsaval wrote: ↑Thu Mar 31, 2022 2:15 pm
The current workflow does not support entering PR IDs. This would need additional logic.
Posted: Fri Apr 01, 2022 9:58 am
by ppd
https://docs.github.com/en/actions/lear ... age-limits
As of now, there's no such thing as a "x minutes per month is free" limit. There's limited concurrency, i.e. only 20 jobs can run in parallel in the free tier.
For automated testing? Sure. In principle, a snap is just a bundle of whatever you compile with all its dependencies. If you configure the project so that it includes/builds its tests, you can run them from the snap.
Of course, the used snapcraft recipe must be compatible with the state of FreeCAD at the time of the commit. For example, the edge snap uses a very recent OCCT release, which is incompatible with older PRs. In this case, you'd need to maintain a separate snapcraft.yaml for older commits or rebase the PR itself.
At the moment, we have two branches: master and stable. The stable snapcraft.yaml, which is used for the releases (e.g. 0.19.4), could be a good fit for older PRs.
Posted: Thu Apr 21, 2022 11:57 am
by ppd
A new branch has been added to build testing snaps from the stable recipe instead of the edge recipe:
https://github.com/ppd/freecad-ppd/tree/stable-manifest
This allows building PRs that are not (yet) compatible with OCCT 7.6.1 et al.
