Addon Manager Dependency Update
chennes
Re: Addon Manager Dependency Update
Post by chennes »
drmacro wrote: Thu Feb 17, 2022 12:37 pm Apologies if this is the wrong thread...
This one works, I'm subscribed to it so I'll see your posts. That's been on my "to investigate" list for a while, I'll bump up the priority.
Chris Hennes
Pioneer Library System
falviani
Post by falviani »
Hi Chris,
Not behind any kind of proxy. Pulled the latest and built, but the same error has occurred.
-Frank
chennes
Post by chennes »
Is it failing right away, or do you see the "Checking for connection" dialog for some time?
Chris Hennes
Post by Kunda1 »
Having an issue loading dependencies for InventorLoader
I'm not sure if it is because the package.xml is pointing to the wrong default branch (https://github.com/jmplonka/InventorLoader/pull/55/) or what..but 3rd party deps aren't being installed.
1. Run Addon Manager
2. Choose InventorLoader
3. Click 'Install'
4. Dialog letting me know what 3rd party dependencies are needed and if I want FC to grab them. I press 'Yes'
Result: Dialog box "Installing dependencies" with a cancel button
Output in the CLI
Addon Manager internal error: lost metadata for package sheetmetal
Noneb'pip 22.0.3 from /snap/freecad-ppd/161/lib/python3.8/site-packages/pip (python 3.8)\n'pip 22.0.3 from /snap/freecad-ppd/161/lib/python3.8/site-packages/pip (python 3.8)
  File "/snap/freecad-ppd/161/usr/Mod/AddonManager/addonmanager_workers.py", line 1326, in run
    self.emit.failure(
AttributeError: 'builtin_function_or_method' object has no attribute 'failure'
OS: Ubuntu Core 20 (KDE/plasma)
Version: 0.20.27571 (Git)
Hash: 0bbc253ddee6801770c78e011c5201b7c2c36080
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, OCC 7.5.2
Installed mods:
  * ToolbarStyle
  * stickframe
  * sheetmetal 0.2.49
  * Behave-Dark-Colors 0.0.1
  * Curves 0.3.0
  * Ship
  * BIM 2021.12.0
chennes
Post by chennes »
falviani wrote: Thu Feb 17, 2022 4:44 pm Hi Chris,
-Frank
I'd be curious to know if git commit f28278dca5ffeb5928799f3356b6a9aed0c38d20 resolves the issue for you.
Chris Hennes
chennes
Post by chennes »
Kunda1 wrote: Thu Feb 17, 2022 5:05 pm Having an issue loading dependencies for InventorLoader
It's a bug in the error-handling code, fixed now in git commit 03fa2f398.
Chris Hennes
drmacro
Post by drmacro »
chennes wrote: Fri Feb 18, 2022 2:48 pm
Just pulled and built, seems fixed:
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.27635 (Git)
Hash: 39603258210d24f09aef1fe96271f6c6ca595f5a
Python 3.7.3, Qt 5.11.3, Coin 4.0.0a, OCC 7.3.0
Installed mods:
* kicadStepUpMod 10.10.4
* Manipulator
* DynamicData 2.32.0
* fasteners 0.3.38
* fcgear
* Defeaturing
* Assembly4 0.11.9
* OpticsWorkbench 1.0.7
* workfeature-macro
* sheetmetal 0.2.49
* A2plus 0.4.54b
* CurvedShapes 1.0.0
* Curves 0.3.0
falviani
Post by falviani »
Hi Chris,
Still having the same isues connecting to GitHub. My firewall doesn't block it and I can see it in FireFox, as shown below:
I have no idea what's happening. I did a pull this morning and updated the OS, just in case. Just out of curiosity, how are you connecting to GitHub?
-Frank
chennes
Post by chennes »
falviani wrote: Fri Feb 18, 2022 5:03 pm I did a pull this morning
I don't know what timezone you are in: did that pull include git commit f28278dca5ffeb5928799f3356b6a9aed0c38d20?
Chris Hennes
falviani
Post by falviani »
Hi Chris,
Fair ambiguity observation: I'm in the Central Time Zone, outside Chicago.
I just did a pull (1:30 CST) and rebuild, and checked to see that the referenced git change is included. No change.
The weekly build is just fine and brings up the addon manager as expected. So it must be something about my build configuration :( The stats from that are:
OS: Windows 10 Version 2009
Version: 0.20.25645 (Git)
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
