For clarification: The goal is to run cmake in a certain way, so FreeCAD produces a source-tarball. Did I understand this correctly? If so what about all the dependencies? I would like to avoid any dependencies in this step.
creating source releases
Re: creating source releases
The procedure is to checkout the git repo on a system. You then run cmake to generate the Makefiles and start with make the build process. As soon as the target FreeCADApp starts it creates the file Version.h. Here you can break the build and run make dist-git to create the source tarball.
If you mean with dependencies cmake, the libs, the compiler, ... then I don't know a way to achieve this without them.If so what about all the dependencies? I would like to avoid any dependencies in this step.
I don't know if it's possible to create the Version.h with a GH action. IMO, we anyway should implement a solution independent on where the sources are hosted.
But can't you simply create the tarball on a system where you have setup the build environment, upload the source tarball to server somewhere and then get this source tarball for your builds?
How does it work to create the Version.h file? What you need now is a way to extract the:The github action to generate the version file and the compressed source code is already done. My question now is, how to use the version-file in the build process? And which information do we need? Currently the version file looks like this:
- number of commits of the branch
- the date of the last push
- the url of the repositoy
- the hash of the last push
- the name of the branch
wmayer wrote: ↑Sun Oct 31, 2021 10:58 amHow does it work to create the Version.h file? What you need now is a way to extract the:The github action to generate the version file and the compressed source code is already done. My question now is, how to use the version-file in the build process? And which information do we need? Currently the version file looks like this:If there is a file src/Build/Version.h in the sources then this file will be used as it is.
My current approach is to fill the Version.h.cmake file , commit the changes and use "git archive" to create the archive. Look here:
https://github.com/FreeCAD/FreeCAD-Bund ... .py#L38L44
With this aproach I do not have to pull any dependencies, which is nice as the github-action doesn't need a lot of time.
Still not sure where I should fill in the url, hash and branch-name.
- adrianinsaval
weekly release version info is broken atm
OS: Windows 10 (10.0)
Version: 0.20.Unknown
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
Locale: Spanish/Paraguay (es_PY)
- Captura de pantalla 2021-11-03 140216.png (89.65 KiB) Viewed 2583 times
