[Solved] FreeCAD 0.18.3 missing SHA256 for Linux and MacOS
Is there automation code that generates the sha256 for each release ?
Re: FreeCAD 0.18.3 missing SHA256 for Linux and MacOS
No. In the past I've downloaded the packages and generated the SHA256 locally with certutil.
It should be possible to generate it from the travis.yml https://github.com/FreeCAD/FreeCAD-AppI ... travis.yml
and then deploy it at the same time. I don't know the specifics.
"fight the good fight"
Thanks @sgrogansgrogan wrote: ↑Thu Aug 15, 2019 8:57 pmNo. In the past I've downloaded the packages and generated the SHA256 locally with certutil.
When you use certutil, it generates the file with the sha256 in it?
Would it be as simple as running
/usr/bin/sha256sum FreeCAD.AppImage > FreeCAD.AppImage.sha
Yes, this will generate the sha256 then we need to deploy the file(s). Somewhere around here https://github.com/FreeCAD/FreeCAD-AppI ... is.yml#L80
@triplus is the guru for this part.
Will add hash files generation logic for AppImage/DMG files in the following days.
Reference:
https://forum.freecadweb.org/viewtopic. ... 88#p329088
Reference:
Create and deploy SHA-256 hashes support for stable/daily AppImage/DMG files was added today.
