[fixed] conda: win compile error
- adrianinsaval
Re: [fixed] conda: win compile error
the problem is not with the compilation but with uploading the bundles, I found the problem and submitted a fix already so it shouldn't be too long before things go back to normal: https://forum.freecadweb.org/viewtopic. ... 45#p654445
Ok, great, thank you very much!adrianinsaval wrote: ↑Thu Jan 19, 2023 1:56 pm the problem is not with the compilation but with uploading the bundles, I found the problem and submitted a fix already so it shouldn't be too long before things go back to normal: https://forum.freecadweb.org/viewtopic. ... 45#p654445
