I pulled FreeCAD 0.21.0, Libs: 0.21.0R31529 (Git), compiled, installed and started FreeCAD.
OS: openSuse 15.3
As soon as the addon manager is opend in the python terminal these lines appeare:
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_workers_startup.py", line 87, in run
self._retrieve_macros_from_git()
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_workers_startup.py", line 273, in _retrieve_macros_from_git
update_succeeded = self._update_local_git_repo()
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_workers_startup.py", line 326, in _update_local_git_repo
macro_cache_location,
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_git.py", line 83, in clone
self._synchronous_call_git(final_args)
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_git.py", line 364, in _synchronous_call_git
proc = utils.run_interruptable_subprocess(final_args)
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_utilities.py", line 434, in run_interruptable_subprocess
encoding="utf-8",
TypeError: __init__() got an unexpected keyword argument 'text'
encoding="utf-8",
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_workers_startup.py", line 554, in run
checker.check_package(repo)
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_workers_startup.py", line 629, in check_package
self.check_workbench(package)
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_workers_startup.py", line 586, in check_workbench
status = self.git_manager.status(clonedir)
File "/opt/FreeCAD/Mod/AddonManager/addonmanager_git.py", line 145, in status
status = self._synchronous_call_git(["status", "-sb", "--porcelain"])
encoding="utf-8",
encoding="utf-8",
I assume that the BIM installation does not work due to these error messages: I hope it is easy to fix.
Please advice if more info is needed.
