I am trying to install freecad through conda (following the instructions in https://wiki.freecadweb.org/Conda), which I did many times before.
Now, when I do so, (with conda or mamba) I get a message error that freecad is not found:
PackagesNotFoundError: The following packages are not available from current channels:
- freecad
Current channels:
- https://conda.anaconda.org/conda-forge/osx-arm64
- https://conda.anaconda.org/conda-forge/noarch
- https://repo.anaconda.com/pkgs/main/osx-arm64
- https://repo.anaconda.com/pkgs/main/noarch
- https://repo.anaconda.com/pkgs/r/osx-arm64
- https://repo.anaconda.com/pkgs/r/noarch
Do you know if there is any problem with the conda-forge channel?
My hardware is a macbook pro (with M1 pro chip).
Thanks!
Biel
