[Solved] Building fail
xXxStYxXx
Post by xXxStYxXx »
Hello, I'm trying to make an out-of-source build of FreeCAD. I pulled the latest source code of FreeCAD which is version 0.20, installed all required libraries and packages.
I followed the Compile on Linux guide and faced a problem with building FreeCAD. Firstly I created folders for both source code and future build.
Then I ran CMAKE to configure environment with this command:
cmake ../freecad-source
Seems like CMAKE did it job, I got this output:
-- Compiler: GNU, version: 7.5.0
-- prefix: /usr/local
-- bindir: bin
-- datadir: share
-- docdir: share/doc/FreeCAD
-- includedir: include
-- libdir: lib
-- cmake: 3.10.2
-- PyCXX found:
--   Headers:  /home/sapr/freecad-source/src
--   Sources:  /home/sapr/freecad-source/src/CXX
--   Version:  7.1.7
-- -- OpenCASCADE Community Edition has been found.
-- -- Found OCE/OpenCASCADE version: 6.9.1
-- -- OCE/OpenCASCADE include directory: /usr/lib/x86_64-linux-gnu/oce-0.17/../../../include/oce
-- -- OCE/OpenCASCADE shared libraries directory:
-- The imported target "vtkRenderingPythonTkWidgets" references the file
   "/usr/lib/x86_64-linux-gnu/libvtkRenderingPythonTkWidgets.so"
but this file does not exist.  Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
   "/usr/lib/cmake/vtk-7.1/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtk" references the file
   "/usr/bin/vtk"
-- The imported target "pvtk" references the file
   "/usr/bin/pvtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkFiltersParallelDIY2;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
-- Check for medfile (libmed and libmedc) ...
-- We guess that libmed was built using hdf5-openmpi version
-- Boost version: 1.65.1
-- Found the following Boost libraries:
--   filesystem
--   program_options
--   regex
--   system
--   thread
--   date_time
--   chrono
--   atomic
-- Performing Test _flag_found
-- Performing Test _flag_found - Success
ModuleNotFoundError: No module named 'pivy'
shiboken2 not found.
PySide2 not found.
ModuleNotFoundError: No module named 'shiboken2'
shiboken Python module not found.
ModuleNotFoundError: No module named 'PySide2'
PySide2 Python module not found.
-- Found Matplotlib: /usr/lib/python3/dist-packages/matplotlib (found version "2.1.1")
-- Platform is 64-bit, set -D_OCC64
-- [E57] Revison ID: E57Format-2.2.1-x86_64-linux-gcc7
-- [E57] Building static library
-- setting gcc options: -Wall -Werror -Wno-deprecated -pedantic-errors
CMake Warning at /usr/share/cmake-3.10/Modules/FindBoost.cmake:1626 (message):
  No header defined for python36; skipping header check
  src/Mod/Path/libarea/CMakeLists.txt:23 (find_package)
-- Could NOT find Boost
  No header defined for python3; skipping header check
  src/Mod/Path/libarea/CMakeLists.txt:26 (find_package)
--   python3
-- found Boost: 1_65_1
-- boost-incude dirs are: /usr/include
-- boost-python lib is:
-- boost_LIBRARY_DIRS is: /usr/lib/x86_64-linux-gnu
-- Boost_LIBRARIES is: /usr/lib/x86_64-linux-gnu/libboost_python3.so
-- area module (for Path Workbench) will be installed to: lib
-- Note: Doxygen docs will look better with graphviz's dot installed.
-- Coin3D doc is not installed
Summary report
-- Build type:
-- Compiler:            /usr/bin/c++ (7.5.0)
-- Flags:               -Wall -Wextra -Wno-write-strings
-- Standard:            Requires C++17
-- Python:              3.6.9 [/usr/bin/python3] []
-- PCL:                 not enabled
-- pybind11:            not enabled
-- Boost:               106501
-- XercesC:             3.2.0 [/usr/lib/x86_64-linux-gnu/libxerces-c.so] [/usr/include]
-- ZLIB:                1.2.11
-- PyCXX:               7.1.7 [/home/sapr/freecad-source/src]
-- OCC:                 6.9.1 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat] [] [/usr/lib/x86_64-linux-gnu/oce-0.17/../../../include/oce]
-- SMESH:               7.7.1.0 build internal
-- MEDFile:             3.0.6 [/usr/lib/x86_64-linux-gnu/libmedC.so] [/usr/include]
-- HDF5:                1.8.13
-- VTK:                 7.1.1
-- NETGEN:              not enabled
-- SWIG:                3.0.12
-- Eigen3               3.3.4
-- Qt5Core:             5.9.5
-- Qt5Network:          5.9.5
-- Qt5Xml:              5.9.5
-- Qt5XmlPatterns:      5.9.5
-- Qt5Widgets:          5.9.5
-- Qt5PrintSupport:     5.9.5
-- Qt5OpenGL:           5.9.5
-- Qt5Svg:              5.9.5
-- Qt5UiTools:          5.9.5
-- Qt5Concurrent:       5.9.5
-- Qt5WebKitWidgets:    5.212.0
-- Designer plugin:     not built per user request (BUILD_DESIGNER_PLUGIN)
-- Shiboken2:            [Shiboken2_DIR-NOTFOUND] []
-- PySide2:              []
--  IncludeDir:         Unable to find, python version mismatch?
-- PySide2Tools:        [/usr/bin/pyuic5] [/usr/bin/pyrcc5]
-- Freetype:            2.8.1
-- OpenGL:              /usr/lib/x86_64-linux-gnu/libGL.so
-- OpenGLU:             [/usr/lib/x86_64-linux-gnu/libGLU.so][/usr/include]
-- Coin3D:              4.0.0 [/usr/lib/x86_64-linux-gnu/libCoin.so] [/usr/include]
-- Pivy:
-- SPNAV:               [/usr/lib/libspnav.so] [/usr/include]
-- Matplotlib:          2.1.1
-- Rift:                not enabled (BUILD_VR)
-- Doxygen:             1.8.13
-- Language:            English
-- Coin3D_DOC:          not found
Now run 'cmake --build /home/sapr/freecad-build' to build FreeCAD
-- Configuring done
-- Generating done
-- Build files have been written to: /home/sapr/freecad-build
And after that all I had to do is to run this command:
make -j$(nproc --ignore=2)
But my build instantly fails with this error message:
[  0%] Linking CXX shared library ../../../lib/libMEFISTO2.so
/usr/bin/ld: cannot find -lTKVCAF
src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/build.make:163: recipe for target 'lib/libMEFISTO2.so' failed
make[2]: *** [lib/libMEFISTO2.so] Error 1
CMakeFiles/Makefile2:366: recipe for target 'src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/all' failed
make[1]: *** [src/3rdParty/salomesmesh/CMakeFiles/MEFISTO2.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
And I can't figure out what this error means. I found kinda the same topic with "cannot find -lTKVCAF" part but it didn't really help me.
So I wanted to know if anyone can explain what seems to be a problem here?
I'm actually new to both FreeCAD and Ubunthu/Linux so if I missed something important, please let me know
I'm using virtual machine with Ubunthu 18.04.6 LTS 64-Bit Oracle
waebbl
Re: Building fail
Post by waebbl »
xXxStYxXx wrote: Sun Sep 25, 2022 9:54 pm Seems like CMAKE did it job, I got this output:
The CMake configuration output contains several errors and IMO shouldn't have succeeded.
  • Pivy, which AFAIK is mandatory is not installed or found:
  • Both, shiboken2 and pyside2 are missing or not found:
    PySide2 not found.
    and in the summary report
    -- PySide2:              []
The three packages might actually be installed, but not found. Possible reason could be they were built for a different Python version.
One reason for the compile issue could be you are using the Community Edition of OpenCASCADE:
Although the option is still in the CMake files current FreeCAD versions don't support OCE very well. The recommendation nowadays is to use the Official Version of OCCT.
xXxStYxXx
Re: Building fail
Post by xXxStYxXx »
Thanks, I started with fixing all CMake compiling errors. Old errors about pivy, shiboken2 and pyside2 are gone now.
But some new errors appeared and I can't understand why they even appeared
Firstly this:
I tried to search for vtkRenderingPythonTkWidgets and got this output:
~$ sudo apt-file search vtkRenderingPythonTkWidgets
python-vtk6: /usr/lib/python2.7/dist-packages/vtk/libvtkRenderingPythonTkWidgets.x86_64-linux-gnu.so
So I guess the file kinda exists but under another name. Do I have to somehow specify this file path to CMake?
And I think the same problem with these two:
   "/usr/bin/vtk"
And here it's trying to reference a whole folder, output:
~$ sudo apt-file search /usr/bin/vtk
libvtk6-java: /usr/bin/vtkParseJava-6.3
libvtk6-java: /usr/bin/vtkWrapJava-6.3
libvtk7-java: /usr/bin/vtkParseJava-7.1
libvtk7-java: /usr/bin/vtkWrapJava-7.1
openfoam: /usr/bin/vtkUnstructuredToFoam
paraview-dev: /usr/bin/vtkWrapClientServer
python-vtk6: /usr/bin/vtk6python
python-vtk6: /usr/bin/vtkWrapPython-6.3
python-vtk6: /usr/bin/vtkWrapPythonInit-6.3
python3-vtk7: /usr/bin/vtkWrapPython-7.1
python3-vtk7: /usr/bin/vtkWrapPythonInit-7.1
tcl-vtk6: /usr/bin/vtkWrapTcl-6.3
tcl-vtk6: /usr/bin/vtkWrapTclInit-6.3
tcl-vtk7: /usr/bin/vtkWrapTcl-7.1
tcl-vtk7: /usr/bin/vtkWrapTclInit-7.1
vtk6: /usr/bin/vtk6
vtk6: /usr/bin/vtkEncodeString-6.3
vtk6: /usr/bin/vtkHashSource-6.3
vtk6: /usr/bin/vtkParseOGLExt-6.3
vtk6: /usr/bin/vtkWrapHierarchy-6.3
vtk7: /usr/bin/vtk7
vtk7: /usr/bin/vtkEncodeString-7.1
vtk7: /usr/bin/vtkHashSource-7.1
vtk7: /usr/bin/vtkParseOGLExt-7.1
vtk7: /usr/bin/vtkWrapHierarchy-7.1
Same goes for pvtk:
   "/usr/bin/pvtk"
But pvtk actually exists:
~$ sudo apt-file search /usr/bin/pvtk
python-vtk6: /usr/bin/pvtk
python-vtk6: /usr/bin/pvtkpython
And quick question, CMake claiming it can't find Boost library and after that instantly finds Boost:
--   python3
I'm not sure if it's gonna be a problem in future.
And just in case the whole output of CMake:
-- bindir: bin
-- datadir: share
-- libdir: lib
-- cmake: 3.10.2
-- PyCXX found:
--   Version:  7.1.7
-- -- Found OCE/OpenCASCADE version: 7.5.2
-- -- OCE/OpenCASCADE include directory: /usr/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /usr/lib/x86_64-linux-gnu
   "/usr/bin/vtk"
   "/usr/bin/pvtk"
--   filesystem
--   program_options
--   regex
--   system
--   thread
--   date_time
--   chrono
--   atomic
-- Shiboken2Config: Using default python: -python2.7.x86_64-linux-gnu
-- libshiboken built for Release
-- PYTHON_CONFIG_SUFFIX: .cpython-36m-x86_64-linux-gnu
-- PySide2 Python module found at /home/sapr/.local/lib/python3.6/site-packages/PySide2.
--   python3
Summary report
-- Build type:
-- Python:              3.6.9 [/usr/bin/python3] [.cpython-36m-x86_64-linux-gnu]
-- PCL:                 not enabled
-- Boost:               106501
-- ZLIB:                1.2.11
-- OCC:                 7.5.2 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat] [/usr/lib/x86_64-linux-gnu] [/usr/include/opencascade]
-- HDF5:                1.8.13
-- VTK:                 7.1.1
-- SWIG:                3.0.12
-- Eigen3               3.3.4
-- Qt5Core:             5.9.5
-- Qt5Xml:              5.9.5
-- Qt5OpenGL:           5.9.5
-- Qt5Svg:              5.9.5
-- Qt5WebEngineWidgets: 5.9.5
-- Shiboken2:           5.11.2 [/usr/lib/x86_64-linux-gnu/cmake/Shiboken2-5.11.2] [/usr/include/shiboken2]
-- PySide2:             5.11.2 [/usr/include/PySide2]
-- Freetype:            2.8.1
-- Pivy:                0.6.5a0
-- Doxygen:             1.8.13
-- Configuring done
-- Generating done
Founder
Re: Building fail
Post by wmayer »
I have XUbuntu 18.04 and I get the exact same messages about vtk. So, you can completely ignore them.
If you run CMake Configure and the last message is "Configuring done" then all CMake checks have passed. The error you posted in your first post was
and here lies the problem. Apparently you use the official liboce packages which are deprecated and we haven't tested them any more for a long time. Because none of the liboce packages provide the file libTKVCAF.so you run into this linker error.
As a test you can edit the file FindOCC.cmake and remove TKVCAF in line 155. Repeat the build process and in case it succeeds run the self-tests with ./bin/FreeCADCmd -t 0
If this all works without problems we could prepare a fix for FindOCC.cmake. In case you run into more problems you should replace OCE with the unofficial OCCT packages. In order to do so follow the instructions at https://launchpad.net/~freecad-maintain ... ecad-daily
After adding the PPA
deb https://ppa.launchpadcontent.net/freecad-maintainers/freecad-daily/ubuntu bionic main
and refreshing the cache you should be able to install libocct-data-exchange-7.3, libocct-data-exchange-dev, libocct-draw-dev, libocct-foundation-dev, libocct-modeling-algorithms-dev, libocct-modeling-data-dev, libocct-ocaf-dev and libocct-visualization-dev.
You probably have to uninstall all liboce*-dev packages beforehand.
xXxStYxXx
Re: Building fail
Post by xXxStYxXx »
Yeah, so it built successfully, honestly I didn't even try anything you suggested besides probably replacing OCE with OCCT because I did that before I left the first replay and didn't even try to build again. Now I think it was causing the problem.
Later I will start from the scratch and clarify how I fixed it, because I also built a ton of workbenches I won't use.
Thanks a lot in any case
xXxStYxXx
Re: Building fail
Post by xXxStYxXx »
So, I moved from Ubuntu 18.04 to 22.04 because I think 18.04 version has a lack of required packages and manually installing them led me to editing source.list which caused system errors (most likely my fault). And 22.04 version works perfectly, all you have to do is run this command
sudo apt build-dep freecad
from the Compiling on Linux tutorial and all will be done for you. The only thing you would probably want to do is additionally install python3-pyside2.qtnetwork, python3-pyside2.qtwebengine*, python3-pyside2.qtwebchannel because FreeCAD will warn you about those packages, at least it did for me.
