master build - shibroken- resolved
freman
Post by freman »
I tried to update master and after solving a regression with Coin3D cmake file I did get a clean build. However, I get runtime failures from shiboken and cannot do anything with FreeCAD.
On start up:
  File "/usr/lib64/python3.10/site-packages/shiboken2/files.dir/shibokensupport/__feature__.py", line 142, in _import
<class 'ImportError'>: /~/freecad-build-master/Mod/Mesh/Mesh.so: undefined symbol: _ZN4Base5Line3IdEC1ERKNS_7Vector3IdEES5_
here are the relevant lines from cmake output:
-- Designer plugin:     not built per user request (BUILD_DESIGNER_PLUGIN)
-- Shiboken2:           5.15.2 [/lib64/cmake/Shiboken2-5.15.2] [/usr/include/shiboken2;/usr/include/python3.10]
-- PySide2:             5.15.2 [/usr/include/PySide2]
Can anyone cast any light on what to do here?
TIA.
OS: Fedora Linux 35 (Thirty Five) (LXQt//usr/share/xsessions/lxqt)
Version: 0.21.29925 (Git)
Hash: 322080d4f114d0d27083729f3a2db53242ae3f4d
Python 3.10.5, Qt 5.15.2, Coin 4.0.0, Vtk 9.0.3, OCC 7.5.0
Installed mods:
  * FreeCAD_Assembly4 0.11.10
  * FreeCAD_assembly3
freman
Re: master build - shibroken
Post by freman »
I just tried starting a previously working master build from May 2022. It shows a similar message with an undefined symbol, though is a different context.
08:57:13  During initialization the error "module 'FreeCAD' has no attribute 'EndingAdd'" occurred in /~/freecad-build-master.clone/Mod/Image/InitGui.py
08:57:13  Please look into the log file for further information
08:57:13  During initialization the error "module 'FreeCAD' has no attribute 'EndingAdd'" occurred in /~/freecad-build-master.clone/Mod/Spreadsheet/InitGui.py
08:57:17  /~/freecad-build-master.clone/Mod/Path/Path.so: undefined symbol: _ZN4Base7Vector3IdEC1ERKS1_
08:57:17  Wizard shaft module cannot be loaded
08:57:17  /~/freecad-build-master.clone/Mod/PartDesign/PartDesignGui.so: undefined symbol: _ZN4Base7Vector3IdEaSERKS1_
It seems the chopping and changing I had to do in trying to resolve the Coin cmake changes may have broken something else.
Any Ideas on where to look to get this working again ?
Founder
Post by wmayer »
freman wrote: Fri Aug 05, 2022 8:26 am However, I get runtime failures from shiboken and cannot do anything with FreeCAD
shiboken isn't the problem. shiboken has implemented a special import loader mechanism as discussed here https://forum.freecadweb.org/viewtopic. ... 20#p397620 and this always jumps in if a module has failed to load. If also shiboken's import loader fails then the reported error message contains something with shiboken. Unfortunately this distracts from the actual problem.
Your actual problem is this linker error:
It's about the class Base::Line3 that has been added to FreeCADBase recently and used by the Mesh module. You probably have to do a clean rebuild.
freman
Post by freman »
Hi, thanks for the explanation.
I have done a clean rebuild of opencascade, opencamlib which I build locally and a clean installation of FC, with the cmake change you suggested in the other thread.
It is somewhat cleaner but I'm still getting similar errors:
11:39:11  1.550142 <asm3.main> init_gui.py(14): no solver backend found
11:39:11  /usr/local/lib64/Import.so: undefined symbol: _ZN24BRepBuilderAPI_MakeShape5BuildEv
Still getting a [word censored] load of errors when I open a previous project
11:45:05  Cannot create object 'Body': (/usr/local/lib64/PartGui.so: undefined symbol: _ZN24BRepBuilderAPI_MakeShape5BuildEv)
11:45:05  Cannot create object 'Sketch': (/usr/local/lib64/PartGui.so: undefined symbol: _ZN24BRepBuilderAPI_MakeShape5BuildEv)
11:45:05  Cannot create object 'Job001': (/usr/local/lib64/Import.so: undefined symbol: _ZN24BRepBuilderAPI_MakeShape5BuildEv)
11:45:05  Cannot create object 'TC__Default_Tool': (/usr/local/lib64/Import.so: undefined symbol: _ZN24BRepBuilderAPI_MakeShape5BuildEv)
11:45:05  Cannot create object '_0_Deg__V_Bit': (/usr/local/lib64/Import.so: undefined symbol: _ZN24BRepBuilderAPI_MakeShape5BuildEv)
11:45:05  Cannot create object 'Vcarve': (/usr/local/lib64/Import.so: undefined symbol: _ZN24BRepBuilderAPI_MakeShape5BuildEv)
11:45:05  Cannot create object 'Deburr': (/usr/local/lib64/Import.so: undefined symbol: _ZN24BRepBuilderAPI_MakeShape5BuildEv)
Founder
Post by wmayer »
If I got you right you use a local build of OCC that is linked by your FreeCAD build. Do you additionally have a system OCC version installed?
If yes, then your installed FreeCAD version apparently tries to load that OCC version and due to binary incompatibilities it fails. To fix this you must define the environment variable LD_LIBRARY_PATH accordingly.
I recommend to write a freecad.sh script that sets the environment variable and executes FreeCAD. You then have to use this script when starting FreeCAD.
The file would be like this:
#!/bin/sh
export LD_LIBRARY_PATH=<<--- Put here the abs. path to your local OCC's lib directory -->>
<<--- Put here the abs. path to the FreeCAD executable -->>
Then make the script executable with
chmod u+x freecad.sh
freman
Post by freman »
Thanks.
In principal I only have the local build of OCC , though with all the to-ing an fro-ing with chasing down the cmake problem I do not have 100% confidence there is not some cruft left somewhere.
There is also the possibility that the package manager removed some deps when I uninstalled the distro Coin pkg that I needed to keep, though I do have a clean build compiling correctly so in principal all is there.
printenv tells me :
LD_LIBRARY_PATH=/usr/local/lib:/usr/lib64/openmpi/lib/:/usr/local/lib64/
I run FC directly from the build tree with ./FreeCAD , which is what I have always done in several years of building master FreeCAD.
freman
Post by freman »
OK , I was confused after all the back and forth.
I am using distro provided opencascasde 7.5.0 , Coin4 and only OCL is built locally.
I cleaned out all the OCC files manually ( since they don't provide make uninstall target ).
I deleted the entire FreeCAD build tree and did a clean build.
-- OCC:                 7.5.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat] [/usr/lib64] [/usr/include/opencascade]
-- SMESH:               7.7.1.0 build internal
Still essentially the same problem:
12:08:48  Traceback (most recent call last):
<class 'ImportError'>: ~/freecad-build-master/Mod/Mesh/Mesh.so: undefined symbol: _ZN4Base5Line3IdEC1ERKNS_7Vector3IdEES5_
12:08:48  ~/freecad-build-master/Mod/Mesh/Mesh.so: undefined symbol: _ZN4Base5Line3IdEC1ERKNS_7Vector3IdEES5_
Fedora offers smesh-9.6.0 , am I better using that or the built-in 7.7.1.0 ? Is the Mod/Mesh problem related to smesh ?
How can that be done ? -DBUILD_SMESH=OFF does not seem to change this.
Thanks for your help .
Founder
Post by wmayer »
No, it's totally unrelated.
/svn/freecad-build-master/Mod/Mesh/Mesh.so: undefined symbol: _ZN4Base5Line3IdEC1ERKNS_7Vector3IdEES5_
This function requires this type.
For some reason your libFreeCADBase.so seem to lack of the symbols of Base::Line3f and Base::Line3d.
What's the output of
nm libFreeCADBase.so | grep Line3
freman
Post by freman »
 nm ../lib/libFreeCADBase.so | grep Base5Line3IdEC
00000000002d1738 W _ZN4Base5Line3IdEC1EOS1_
00000000002d17ae W _ZN4Base5Line3IdEC1ERKNS_7Vector3IdEES5_
00000000002d16ea W _ZN4Base5Line3IdEC1ERKS1_
00000000002d1738 W _ZN4Base5Line3IdEC2EOS1_
00000000002d17ae W _ZN4Base5Line3IdEC2ERKNS_7Vector3IdEES5_
00000000002d16ea W _ZN4Base5Line3IdEC2ERKS1_
There we find the thing it says is missing but I had to point it to the right directory.
$ nm ../lib/libFreeCADBase.so | grep _ZN4Base5Line3IdEC1ERKNS_7Vector3IdEES5_
AH, I FOUND IT.
find /usr -iname libFreeCADBase.so
find: ‘/usr/share/empty.sshd’: Permission denied
find: ‘/usr/share/polkit-1/rules.d’: Permission denied
find: ‘/usr/libexec/initscripts/legacy-actions/auditd’: Permission denied
/usr/local/lib64/libFreeCADBase.so
There is a bunch of FreeCAD stuff in there, dated 4th Aug 2022. I'm guessing that I accidentally ran install on FreeCAD on one of a dozen builds I've done in the past few days. As we've seen that is in my load path so was getting pulled in first.
Cleaning that out and it seems to be working without error now . PHEW.
Many thanks for the insider knowledge. There is no way I would have got from those cryptic messages to the cause of this without your expertise.
