Trouble building master: missing coin3d
freman
Post by freman »
after having some instabilities I decided to delete the entire master tree and build directory and start afresh.
I also have a local build of opencascade. Coin3d-4.0.0 Coin3D-devel and pivy are distro installed ( Fedora ).
cmake  -Wno-dev -S../FreeCAD  -DBUILD_QT5=ON -DPYTHON_EXECUTABLE=/usr/bin/python3  -DCCACHE_PROGRAM=
-- Found SWIG: /bin/swig (found version "4.0.2")
-- Found Eigen3: /usr/include/eigen3 (found suitable version "3.3.9", minimum required is "2.91.0")
CMake Error at /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
  Could NOT find Coin3D (missing: COIN3D_INCLUDE_DIRS)
  /usr/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE)
  /usr/share/cmake/Modules/FindCoin3D.cmake:75 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  cMake/FreeCAD_Helpers/SetupCoin3D.cmake:9 (find_package)
  CMakeLists.txt:73 (SetupCoin3D)
If I build coin3d-4.0.1 from source FreeCAD finds it OK and master builds. However this causes problems with distro pivy which has deps on distro coin .... and I'm going round in circles. I include this fact to show it does build without other issues when I build coin3d as well. The missing pivy thows errors on loading.
I've been going back and forth for days trying to get a working build and can't see why this no longer works like it did 3 or 4 weeks back last time I built master.
Any ideas ?
TIA.
adrianinsaval
Re: Trouble building master: missing coin3d
Post by adrianinsaval »
probably due to git commit 7a198ca
what version of Fedora and cmake are you running?
freman
Post by freman »
Thanks for the suggestion but that test does return a finite result.
python -c "import pivy as p; print(p.__version__,end='')"
0.6.7
cmake version 3.22.2
Plus that test comes after the Coin test, and mine seems to be dropping out on Coin.
I have found a difference in the structure of the distro installation and source build. I'd guess that this is throwing it.
/usr/local/include/Inventor
/usr/include/Coin4/Inventor
Any idea what I need to do to tell it where to look ?
Thanks.
FreddyFreddy
Post by FreddyFreddy »
The referenced commit deleted the FreeCAD version of SetupCoin3D.cmake, preferring the cmake internal one. The FreeCAD version had some extra paths. Maybe your setup needs one or more of these?
freman
Post by freman »
Ah, thanks Freddy. I had not realised that commit removed an entire file. I thought it was just the four extra lines. That's almost certainly the cause of the problem.
Now what do I need to do to fix it ? Where is the cmake code for this, I don't see any addition.
FreddyFreddy
The cmake version is a part of cmake.
I'm not knowledgeable on this stuff, but maybe @wmayer can advise?
Founder
Post by wmayer »
freman wrote: Thu Aug 04, 2022 6:19 am Now what do I need to do to fix it ? Where is the cmake code for this, I don't see any addition.
Does your system version of Coin3D provide the file coin-config.cmake (or CoinConfig.cmake)? If yes, then the call of
find_package(Coin CONFIG REQUIRED)
inside SetupCoin3D.cmake should fix it.
Since the file coin-config.cmake (or CoinConfig.cmake) is not necessarily provided by all Coin3D packages for all distributions we have to handle the Coin3D stuff like this:
# Config mode
if (NOT Coin_FOUND)
    find_package(Coin3D REQUIRED)
endif()
Founder
Post by wmayer »
Change the content of SetupCoin3D.cmake to:
macro(SetupCoin3D)
# -------------------------------- Coin3D --------------------------------
    # First try CONFIG mode
    find_package(Coin CONFIG)
    if (Coin_FOUND)
        set (COIN3D_INCLUDE_DIRS ${Coin_INCLUDE_DIR})
        set (COIN3D_LIBRARIES ${Coin_LIBRARIES})
    else()
        # Try MODULE mode now
        if (WIN32 AND MINGW)
            find_path(COIN3D_INCLUDE_DIRS Inventor/So.h)
            find_library(COIN3D_LIBRARIES Coin)
        endif ()
        if(NOT COIN3D_FOUND)
            message(FATAL_ERROR "=================\n"
                                "Coin3D not found.\n"
                                "=================\n")
        endif(NOT COIN3D_FOUND)
    endif()
    IF(NOT PIVY_VERSION)
      execute_process (COMMAND ${Python3_EXECUTABLE} -c "import pivy as p; print(p.__version__,end='')" OUTPUT_VARIABLE PIVY_VERSION)
    ENDIF()
endmacro(SetupCoin3D)
Founder
Post by wmayer »
FYI, this is the official check for Linux platforms:
include(${CMAKE_CURRENT_LIST_DIR}/FindPackageHandleStandardArgs.cmake)
FIND_PACKAGE_HANDLE_STANDARD_ARGS(Coin3D DEFAULT_MSG COIN3D_LIBRARIES COIN3D_INCLUDE_DIRS)
mark_as_advanced(COIN3D_INCLUDE_DIRS COIN3D_LIBRARIES )
while the removed file did this:
    # Try to use pkg-config first...
    find_package(PkgConfig)
    pkg_check_modules(COIN3D Coin)
    # ... then fall back to manual lookup
    IF(NOT COIN3D_FOUND)
      FIND_PATH(COIN3D_INCLUDE_DIRS Inventor/So.h
        ${CMAKE_INCLUDE_PATH}
        /usr/include/Coin3
        /usr/include
        /usr/include/coin
        /usr/local/include
      FIND_LIBRARY(COIN3D_LIBRARIES Coin
        ${CMAKE_LIBRARY_PATH}
        /usr/lib
        /usr/local/lib
        PATH_SUFFIXES Coin2 Coin3
    ENDIF(NOT COIN3D_FOUND)
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Post by babaroga »
I had same problem with Manjaro.
Solved it by manually returning FindCoin3D.cmake to cMake folder. It was deleted by git commit 7a198ca
[code]
OS: Manjaro Linux (KDE/plasma)
Version: 0.21.29938 (Git)
Build type: Unknown
Branch: hlrThreadrc1
Hash: 6159fbafd202429ff1cffca4fd5f93c2407accab
Python 3.10.5, Qt 5.15.5, Coin 4.0.1, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * Manipulator 1.4.5
  * Render 2022.2.0
  * fasteners 0.3.44
  * Assembly4 0.12.0
  * A2plus 0.4.56a
  * sheetmetal 0.2.49
  * InventorLoader 1.3.0
  * Curves 0.4.4
  * kicadStepUpMod 10.13.0
[/code]
