FreeCAD 0.20 Win 11 VS 2022 shiboken2 issues
CandL
Post by CandL »
I have been following the instructions per "https://wiki.freecadweb.org/Compile_on_Windows"
My details:
     - Microsoft (R) C/C++ Optimizing Compiler Version 19.32.31332
     - Python 3.8.10 [b](not the software store, but a direct download)[/b]
          -pip'd in numpy,Pyside2,shiboken2
     - source from https://github.com/sliptonic/FreeCAD
     - cmake version 3.23.2
              using generator "Visual Studio 17 2022" , x64 option
              Out of source build to a new dir.
cmake --build "my build dir" seems to work fine (though CMake config is: Debug;Release;MinSizeRel;RelWithDebInfo, which I have never liked ... I really just want Release, as I don't have debug versions of everything ..... I tried to not use cmake-gui but the command line must be huge)
I build an 2 exes: FreeCADC_d.exe and FreeCADCmd_d.exe
Running FreeCADC_d.exe I get lots of:
"15:47:24  PySide2/__init__.py: Unable to import shiboken2 from  ... followed by a lot of my dirs"
chennes
Re: FreeCAD 0.20 Win 11 VS 2022 shiboken2 issues
Post by chennes »
Which version of the LibPack are you using?
Chris Hennes
Pioneer Library System
CandL
Post by CandL »
LibPack-OCC76-V2
chennes
Post by chennes »
And to clarify, you are using a system-installed version of Python, rather than the one in that LibPack?
Chris Hennes
CandL
Post by CandL »
Not completely sure on that one as CMake may be driving the Python selection.
From the CMake config run I see:
Found Python3: C:/Users/***/github/FreeCAD-LibPack/LibPack-OCC76-V2/bin/python.exe (found version "3.8.10") found components: Interpreter Development Development.Module Development.Embed
Found XercesC: optimized;C:/Users/***/github/FreeCAD-LibPack/LibPack-OCC76-V2/lib/xerces-c_3.lib;debug;C:/Users/***/github/FreeCAD-LibPack/LibPack-OCC76-V2/lib/xerces-c_3D.lib (found version "3.2.2")
Found ZLIB: optimized;C:/Usexxxxx/github/FreeCAD-LibPack/LibPack-OCC76-V2/lib/zlib.lib;debug;C:/Users/***/github/FreeCAD-LibPack/LibPack-OCC76-V2/lib/zlibd.lib (found version "1.2.11")
PyCXX found:
Headers: C:/Users/***/github/FreeCAD/src
Sources: C:/Users/***/github/FreeCAD/src/CXX
Version: 6.2.8
and
Shiboken2Config: Using default python: .cp38-win_amd64
Found PythonInterp: C:/Users/***/github/FreeCAD-LibPack/LibPack-OCC76-V2/bin/python.exe (found suitable version "3.8.10", minimum required is "3")
Found PythonLibs: optimized;C:/Users/***/github/FreeCAD-LibPack/LibPack-OCC76-V2/bin/libs/python38.lib;debug;C:/Users/***/github/FreeCAD-LibPack/LibPack-OCC76-V2/bin/libs/python38_d.lib (found suitable version "3.8.10", minimum required is "3")
SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: 'C:/Users/***/github/FreeCAD-LibPack/LibPack-OCC76-V2/bin/include'
SHIBOKEN_PYTHON_LIBRARIES computed to value: ''
libshiboken built for Release
PySide2 Python module found at C:\Users\****\github\FreeCAD-LibPack\LibPack-OCC76-V2\bin\lib\site-packages\PySide2.
Found Matplotlib: C:/Users/***/github/FreeCAD-LibPack/LibPack-OCC76-V2/bin/lib/site-packages/matplotlib (found version "3.3.3")
Platform is 64-bit, set -D_OCC64
So to me it says CMake is following the FreeCad install rules
GeneFC
Post by GeneFC »
I am not sure what is going wrong.
I just compiled using the standard "Compile on Windows" instructions (exactly) and again everything worked perfectly. Using LibPack-OCC76-V2 and VS 2019.
I always select only "Release" for the actual VS compilation. I change absolutely nothing in terms of dependencies or other files.
If you do not need debug versions then I strongly recommend that you do not allow them to compile. There have been several problems with debug dependencies reported here over the past few months.
Gene
CandL
Post by CandL »
I have been compiling from a VS 2022 admin command window, and NOT using the VS GUI. Should I be able to change the build config to only Release and get the same results?
Oh and I am using VS 2022 (17)
chennes
Post by chennes »
GeneFC wrote: Thu Jul 28, 2022 11:17 pm I always select only "Release" for the actual VS compilation. I change absolutely nothing in terms of dependencies or other files.
Right - in fact, last time I tried I was unable to use any modules that required numpy in anything except Release mode. So while I do compile in Debug most of the time, it means I can't use e.g. Path, etc.
Chris Hennes
CandL
Post by CandL »
Well I kinda held my nose and used MSVS, I have only used their compilers before.
So opening the .sln file ... then selecting Release ..... a few moments later I got a FreeCAD.exe built where I expected it. ( did I miss this in the write up ... that it has to be a sln file, toggle to release, then build?)
Ultimately FreeCad.exe opened as expected ... and the Python console processed:
>>> a=5
>>> print(a)
5
As I am working with the Path module looks like a lot of print statements are in my future ;)
Assuming it works till tomorrow....
So for now I will live with MSVS GUI ...
CandL
Post by CandL »
Well closer but not quite usable... I tried to run:
FreeCADCmd.exe --run-test 0
The common error is: ImportError: DLL load failed while importing FreeCADGui: The specified module could not be found.
ERROR: TestAddonManagerApp (unittest.loader._FailedTest)
ImportError: Failed to import test module: TestAddonManagerApp
  File "C:\Python38\Lib\unittest\loader.py", line 154, in loadTestsFromName
    module = __import__(module_name)
  File "C:\Users\***\github\FreeCAD\FreeCad_build_new\Mod\AddonManager\TestAddonManagerApp.py", line 26, in <module>
    from AddonManagerTest.app.test_utilities import (
  File "C:\Users\***\github\FreeCAD\FreeCad_build_new\Mod\AddonManager\AddonManagerTest\app\test_utilities.py", line 29, in <module>
    from Addon import Addon
  File "C:\Users\****\github\FreeCAD\FreeCad_build_new\Mod\AddonManager\Addon.py", line 30, in <module>
    from addonmanager_macro import Macro
  File "C:\Users\*****a\github\FreeCAD\FreeCad_build_new\Mod\AddonManager\addonmanager_macro.py", line 39, in <module>
    from addonmanager_utilities import remove_directory_if_empty, is_float
  File "C:\Python38\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
  File "C:\Users\****\github\FreeCAD\FreeCad_build_new\Mod\AddonManager\addonmanager_utilities.py", line 34, in <module>
    import FreeCADGui
ERROR:
Now I am launching the exe from an admin command prompt while in the bin dir. Now I thought dlls in the same loc as the exe where loaded automatically as needed.
dir *.exe
 Directory of C:\Users\xxxx\github\FreeCAD\FreeCad_build_new\bin
07/28/2022  08:36 PM           136,704 FreeCAD.exe
07/28/2022  08:30 PM           123,392 FreeCADCmd.exe
dir *.dll
 Volume in drive C is Windows
 Volume Serial Number is 445E-5271
 Directory of C:\Users\****\github\FreeCAD\FreeCad_build_new\bin
07/28/2022  08:29 PM            40,960 Driver.dll
07/28/2022  08:29 PM            31,232 DriverDAT.dll
07/28/2022  08:29 PM            94,208 DriverSTL.dll
07/28/2022  08:29 PM           123,904 DriverUNV.dll
07/29/2022  10:31 AM         4,272,640 FreeCADApp.dll
07/29/2022  10:30 AM         1,629,696 FreeCADBase.dll
07/29/2022  10:28 AM        15,557,120 FreeCADGui.dll
07/28/2022  08:29 PM           102,400 MEFISTO2.dll
07/28/2022  08:31 PM           343,040 NETGENPlugin.dll
07/28/2022  08:28 PM           546,816 SMDS.dll
07/28/2022  08:29 PM         2,591,744 SMESH.dll
07/28/2022  08:28 PM           231,936 SMESHDS.dll
07/28/2022  08:31 PM         2,483,200 StdMeshers.dll
Now I just noticed the Python it is finding is my C:\Python38 , this is a Python 3.8.10 install from python.org. Is this likely the issue?
