python3.9 module 'pivy' has no attribute '__version__'
FreddyFreddy
Post by FreddyFreddy »
bernie@Bernies-iMac ~ % python
Python 3.9.12 (main, Mar 26 2022, 15:51:15)
[Clang 13.1.6 (clang-1316.0.21.2)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import pivy
>>> print(pivy.__path__)
_NamespacePath(['/usr/local/lib/python3.9/site-packages/pivy'])
>>> print(pivy.__version__)
  File "<stdin>", line 1, in <module>
AttributeError: module 'pivy' has no attribute '__version__'
bernie@Bernies-iMac ~ % /usr/local/Cellar/python@3.10/3.10.5/bin/python3.10
Python 3.10.5 (main, Jun 23 2022, 17:15:25) [Clang 13.1.6 (clang-1316.0.21.2.5)] on darwin
>>> import pivy
['/usr/local/lib/python3.10/site-packages/pivy']
0.6.6
OK in python3.10. Is this expected behaviour??
onekk
Re: python3.9 module 'pivy' has no attribute '__version__'
Post by onekk »
as pivy is an external library, probably here is not the right place to ask, maybe at the gihutb page of pivy, but you have to see if there is another way to obtain the "pivy version".
There is not an unique way and "__version__" denote a "internal variable" that should not be used by external calls, using python conventions. Sadly Python will not "hide" internal variables, so it is somewhat a "bad practice" using them.
in my installation of 0.20 that is using the Appimage for Linux:
OS: Artix Linux (openbox)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Italian/Italy (it_IT)
Installed mods:
  * Curves 0.3.0
These are some output from FC Python Console:
import pivy
>>> pivy.sys.api_version
1013
>>> pivy.sys.version
'3.9.13 | packaged by conda-forge | (main, May 27 2022, 17:07:55) \n[GCC 10.3.0]'
>>> pivy.sys.version_info
sys.version_info(major=3, minor=9, micro=13, releaselevel='final', serial=0)
>>> pivy.pivy_meta.__version__
'0.6.6'
>>> pivy.__version__
'0.6.6'
But it may depends by your type of installation, you don't supply any information that permit to guess what type of installation of FC you have, so it could be or not a problem related to FC.
Regards
Carlo D.
- Various other stuffs.
FreddyFreddy
I ask in the context of build, so I think this is the right place.
FindCoin3D.cmake:
 IF(NOT PIVY_VERSION)
    execute_process (COMMAND ${Python3_EXECUTABLE} -c "import pivy as p; print(p.__version__,end='')" OUTPUT_VARIABLE PIVY_VERSION)
  ENDIF()
__version__ is used in cmake summary display. When it fails, it is shown as blank.
I see in source this ability to show version was added some 4 years ago. It looks like I have picked up an older python, perhaps?
waebbl
Post by waebbl »
FreddyFreddy wrote: Sun Jul 24, 2022 12:06 am __version__ is used in cmake summary display. When it fails, it is shown as blank.
Not sure this is the reason for an empty summary display. On Gentoo, the pivy version in the summary has been empty for a long time
-- Coin3D: [/usr/lib64/libCoin.so] [/usr/include]
-- Pivy:
-- SPNAV: [/usr/lib64/libspnav.so] [/usr/include]
Yet
$ python
Python 3.10.5 (main, Jun 8 2022, 00:48:05) [GCC 11.3.0] on linux
>>> import pivy
0.6.7
onekk
Post by onekk »
FreddyFreddy wrote: Sun Jul 24, 2022 12:06 am I ask in the context of build, so I think this is the right place.
FindCoin3D.cmake:
  ENDIF()
Maybe using pivy.pivy_meta.__version__ could be a solution if is present in old and new pivy implementation?
Regards
Carlo D.
FreddyFreddy
That is exactly what the pivy source does.
onekk
Post by onekk »
FreddyFreddy wrote: Sun Jul 24, 2022 9:47 am That is exactly what the pivy source does.
I have not inspected sources, but it could not be too hard to imagine that internally:
__version__ = pivy_meta.__version__
or similar code is used in latest version of pivy
if it is not a big hassle to change the line in the CMAKE to retrieve the "original information" supplied from pivy_meta and not the mirrored on on pivy "main".
Probably it worth to signal it to the maintainer?
Regards
Carlo D.
FreddyFreddy
onekk wrote: Sun Jul 24, 2022 9:53 am if it is not a big hassle to change the line in the CMAKE to retrieve the "original information" supplied from pivy_meta and not the mirrored on on pivy "main"
Except that pivy_meta likely does not exist in this version!
onekk
Post by onekk »
@wmayer What do you think?
Founder
Post by wmayer »
FreddyFreddy wrote: Sat Jul 23, 2022 4:23 am OK in python3.10. Is this expected behaviour??
At least this issue is independent on FreeCAD and likely a bug in pivy. Are the two pivy versions for Py3.9 and Py3.10 built from the exact same sources?
