python3.9 module 'pivy' has no attribute '__version__'
- adrianinsaval
Re: python3.9 module 'pivy' has no attribute '__version__'
that's a question for the folk at pivy and/or for whoever is packaging it for your system.
That's the only change I had to dowmayer wrote: ↑Wed Jul 27, 2022 6:07 amOK, that's fine. We should delete FreeCAD's FindCoin3D.cmake file anyway since there is a system-wide file available. Do you have to change something else to make the Coin3D check working or is it sufficient to delete the file?waebbl wrote: ↑Tue Jul 26, 2022 9:18 pm Just remembered, that I'm removing the FreeCAD provided file during preparation of the source code (patching, etc). So it definitely uses the system provided file, see https://github.com/gentoo/gentoo/blob/m ... build#L144
Just installed pivy with support for python-3.9 as well as python-3.10 and it gives the correct output on print(pivy.__version__) on both occasions. Eventually your issue is related to packaging.FreddyFreddy wrote: ↑Wed Jul 27, 2022 8:07 amAFAICT cmake version was created 14 years ago. But this is a distraction from working out why some pythons have the version of pivy with __version__ and some don't.
@adrianinsaval and @waebbl I'm sure you are both right that this is a packaging issue. BTW I am on MacOS, and there have been a string of problems with the brew stuff lately, don't know if this is related. I just have an error showing and don't myself know enough about the packaging to identify the reason for the error. Maybe it is unimportant, but something ain't right.
From my POV you have several options here:FreddyFreddy wrote: ↑Wed Jul 27, 2022 11:13 pm @adrianinsaval and @waebbl I'm sure you are both right that this is a packaging issue. BTW I am on MacOS, and there have been a string of problems with the brew stuff lately, don't know if this is related. I just have an error showing and don't myself know enough about the packaging to identify the reason for the error. Maybe it is unimportant, but something ain't right.
- If that's possible on MacOS try out different providers and see if their packages work, i.e. pip or pypy
- Report to the brew devs
- Report to the pivy devs
- adrianinsaval
yeah the point I tried to make is that you should ask the right people about that.
Thanks, the patch works as expected.
