apologies if this has been covered before, I tried a search but libpack is a pretty common term
Im trying to build Freecad for Arm64 on windows, and I think I need to rebuild LibPack for Arm64 too.
I spotted cmake folder in the download zip, but im unable to find a 'CMakeLists.txt' file, so im struggling as to where to start.
anyone got any pointers or a guide?
Thanks
Pete
building LibPack
Re: building LibPack
Yes, you have to. The LibPack that we provide covers only the 64-bit architecture.
I don't know what you mean with the CMakeLists.txt file in the LibPack. But as a start have a look at the libraries that are provided by the LibPack because you need all of them for a complete Arm64 build.I spotted cmake folder in the download zip, but im unable to find a 'CMakeLists.txt' file, so im struggling as to where to start.
But this can be quite challenging if you want to build every library on your own. Mainly building Qt will cause you a lot of headache because over the years it has become a huge monster. So, if anyhow possible you should check if a pre-built package for Arm64 is available.
the FreeCAD folder and the xerces library I needed to find and build both had a CMakeLists file which allowed me to just open it in cmake, then once i have the dependencies and library paths correct, generate the build files
I was assuming it would be a similar deal for the LibPack. If not, I best get googling....
- adrianinsaval
the libpack is a binary bundle of many other software that FreeCAD depends on, you'll need to get the source for each one separately and then compile or grab a binary release if available and put it all together, I wish there was more documentation on how to make a libpack from scratch but I think there isn't right now.
that makes sense, I guess I was hoping for an easy fix
