freecad 0.20 won't startup on windows 11(x64) after install
freecad 0.20 won't startup on windows 11(x64) after install. i see the splash screen thats all what happens. after that there happens nothing.. i have i3 pc with 8,00 gb memory (if that something to do with it!!) .freecad 0.19 works fine.
Re: freecad 0.20 won't startup on windows 11(x64) after install
What does it tell if you run from command line? Also could you generate a log?
Do you have a standalone Python version installed?
p from the command line i see only the splash screen. the is nothing like a error message or a command message.
there standing a standalone version on my computer python 3.6.2 (32bit) is that good or bad ?(and why??) and python 2.7.13 (32bit)/python 2.7.14(64-bit) but this is standing all for years in configurationscreen.Do you have a standalone Python version installed?
and windows error log
Foutbucket 1227222236914557437, type 5
Naam van gebeurtenis: BEX64
Antwoord: Niet beschikbaar
Id van CAB-bestand: 0
Handtekening van probleem:
P1: FreeCAD.exe
P2: 0.19.0.16100
P3: 61d388fb
P4: nvoglv64.dll
P5: 27.21.14.5671
P6: 5f75532b
P7: 00000000011584c9
P8: c0000409
P9: 0000000000000007
P10:
Toegevoegde bestanden:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER.4e4f0a8c-ebef-4b4a-8a34-565c259d0ab1.tmp.WERInternalMetadata.xml
Deze bestanden zijn mogelijk hier beschikbaar:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_FreeCAD.exe_a404b5b44fdc3244ec31d69a9fa7a2705b454b_7743670e_84404cbc-88e5-47b2-a050-8245ee65e88d
Analysesymbool:
Opnieuw zoeken naar oplossing: 0
Rapport-id: cd03054f-bc53-48e4-a139-359d4a82113d
Rapportstatus: 268435456
Opgedeelde bucket: 9692eb0f9b3782cec107f81f53c0a1fd
GUID van CAB-bestand: 0
Seems like a graphics driver issue, check if there is an update for your graphics driver, what card do you have?
NVIDIA GeForce GTX 650 Ti
[Solved] freecad 0.20 won't startup on windows 11(x64) after install
i have manual deleted in the folder appdata/ roaming en in the folder appdata/local the freecad folder and i have uninstall freecad 0.19 and freecad 0.20 in the configurationscreen and reinstall freecad 0.20 and after that freecad 0.20 would start.
