I just has the misfortune of "upgrading" to Fed35 since Fed34 is near EOL. Big mistake.
It seems loads of packages have not survived the update and are no longer installed. I've yet to work out if this is some renaming of lack or inclusion in F35.
boost* and lots of *devel files don't seem to be recognised any more.
[EDIT] It seems the problem is something is trying to load old python and boost library versions. See below.
Anyone tried building master on Fed 35 yet , who can advise on tips or whether this is even possible ?
TIA.
This maybe part of the problem. The update moves from python 3.9 to 3.10.4 , shiboken seems to be missing this in cmake:
-- Checking for module 'Coin'
-- Found Coin, version 4.0.0
-- Coin3D libraries found
-- Shiboken2Config: Using default python: .cpython-310-x86_64-linux-gnu
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.10.4", minimum required is "3")
-- Found PythonLibs: /usr/lib64/libpython3.9.so (Required is at least version "3")
-- SHIBOKEN_PYTHON_INCLUDE_DIRS computed to value: '/usr/include/python3.9'
-- SHIBOKEN_PYTHON_LIBRARIES computed to value: ''
-- libshiboken built for Release
-- PYTHON_CONFIG_SUFFIX: .cpython-310-x86_64-linux-gnu
dnf install python3-shiboken2-devel python3-pyside2-devel
Last metadata expiration check: 1:51:20 ago on Mon 09 May 2022 10:17:56 CEST.
Package python3-shiboken2-devel-1:5.15.2-5.fc35.x86_64 is already installed.
Package python3-pyside2-devel-1:5.15.2-5.fc35.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
