Freecad not starting on Ubuntu 22.04
UbunTux
Re: Freecad not starting on Ubuntu 22.04
Post by UbunTux »
adrianinsaval wrote: Tue Apr 26, 2022 5:35 pm alternatively you can extract the appimage, delete the libstc++ library and generate a new appimage with appimagetool, of course using the desktop file or a script is much easier.
Uh... how to say, we will stay on a success... :D
Haavard
Post by Haavard »
UbunTux wrote: Tue Apr 26, 2022 5:54 pm Un grand merci ;-)
De rien :)
toni_lv
Post by toni_lv »
Haavard wrote: Tue Apr 26, 2022 4:59 pm
UbunTux wrote: Tue Apr 26, 2022 4:39 pm I tried it also on Xubuntu 22.04 and it works. I will see how to create a desktop file
Here is an example.
- Extract the attached zip
- Replace "USERNAME" with your username in "freecad.desktop" and "freecad.sh"
- Correct the path to, and name of your Appimage, in "freecad.sh"
- Right click "freecad.sh" and make sure it is executable
- Place "freecad.desktop" and "freecad.sh" in .local/share/applications
- Place the icon folder in .local/share
Voila :)
Thanks a lot, I have just installed Ubuntu 22.04 and the only appimage I have trouble with was this one. In my case it opens perfectly.
electrosteam
Post by electrosteam »
I tried the method suggested by Haavard, but without success, on a Lubuntu system, that was working on 21.10.
The current download for the Appimage was used
Are there any developments on this subject ?
The naming of the desktop file seemed ambiguous to me.
Keep well,
John.
electrosteam wrote: Tue Jul 26, 2022 7:24 am I tried the method suggested by Haavard, but without success, on a Lubuntu system, that was working on 21.10.
Can you be more specific what "without success" means? What is the output if you start from a terminal?
electrosteam
chrisb,
Thanks for taking the time.
I did what Haavard documented, and tried to launch FreeCAD a number of ways:
- double click on the desktop file and select [Execute] in the dialog box,
- open terminal and enter:
- 'freecad',
- 'FreeCAD0.20'.
The two last versions reflect confusion as to the correct name.
Also, my Appimage is spelt with a small 'i', whereas Haavard spells his with a capital "I".
Discovered that my Lubuntu system offers a snap version of FC 0.20, not tried yet.
Of interest, a companion laptop with Ubuntu Mate 21.10 and FC0.20 was upgraded to Ubuntu 22.04 and FC0.20 still operates !
Checked the logs, I could find no events recorded.
Keep well,
John.
electrosteam
FreeCAD 0.20.0 up and running.
I had not absorbed the sequence of suggested trials by posters in the thread, the install of Fuse fixed it.
Not sure I have the desktop icon working properly, but that is a minor thing.
Thanks to all,
John.
KevinBerry
Post by KevinBerry »
I was enjoying FreeCad version 0.22.0.dev and somehow ended up with a Mesa video driver update from 23.0.4 to 24.1 and FreeCad stopped loading.
My solution was to downgrade my Mesa drivers from 24.1 back to 23.0.4. Removing ppa:kisak/kisak-mesa allowed me to automatically downgrade my Mesa video driver and all was well again.
Here are notes that might help you:
1. I believe subscribing to Ubuntu Pro brought on the upgraded video driver which is currently incompatible with the latest FreeCad versions.
2. To see your video driver version: $ glxinfo | grep Mesa
3. I unsubscribed from Ubuntu Pro. Ubuntu Pro didn't cause the ppa:kisak/kisak-mesa to be visible on the Other Software tab of Software Updater, but when I added this repository I received no update to my Mesa driver so I believe Ubuntu Pro was pulling from this. By adding this repository I was able to see the repository on the Other Software Tab and then remove the repository and this automatically downgraded my Mesa drivers to version 23.0.4 which I had before subscribing to Ubuntu Pro because 23.0.4 is what is current with Ubuntu APT. Now the repository is visible and won't disappear and I don't know why it won't disappear, but it remains unchecked.
$ sudo add-apt-repository ppa:kisak/kisak-mesa
$ sudo apt update
$ sudo apt upgrade (nothing upgraded for me so I believe Ubuntu Pro was pulling from this repository)
3. Purging the latest stable repository for Mesa drivers automatically downgraded my Mesa driver to the current APT version 23.0.4 from 24.1.
$ sudo ppa-purge ppa:kisak/kisak-mesa
4. The Ubuntu APT version 19 continued to work for me with Mesa Radeon drivers 23.0.4 and 24.1.
