FYI: Debian Testing build broken (due to debian packaging)
Founder
Re: FYI: Debian Testing build broken (due to debian packaging)
Post by wmayer »
A way would be to build the Debian packages for Py3.9 on your own. Therefore download the files
wget http://archive.ubuntu.com/ubuntu/pool/universe/p/pyside2/pyside2_5.14.0-1~exp1ubuntu5.dsc
wget http://archive.ubuntu.com/ubuntu/pool/universe/p/pyside2/pyside2_5.14.0.orig.tar.xz and
wget http://archive.ubuntu.com/ubuntu/pool/universe/p/pyside2/pyside2_5.14.0-1~exp1ubuntu5.debian.tar.xz
Afterwards run this command
dpkg-source -x pyside2_5.14.0-1~exp1ubuntu5.dsc
that extracts the source files and applies all the patches.
Before continuing with the next step make sure that the symlink python3 points to your python3.9. After that cd into the directory pyside2-5.14.0 and run debuild.
In case you get an error you have to install all listed packages.
Hint: You may have to do the same for shiboken2
Hint: In case you succeed to build the packages open the .deb files and make sure that files have 3.9 in their file names
HarryvL
Post by HarryvL »
Thanks. I will give it a try
vm4dim
Post by vm4dim »
HarryvL wrote: Fri Jun 10, 2022 3:11 pm Hi I am on Ubuntu 20.04. Would you know how I can get my hands on a libshiboken2-dev package with libshiboken2.cpython-39-x86_64-linux-gnu.so ?
Maybe from Ubuntu Impish 21.10
https://packages.ubuntu.com/impish/amd6 ... v/filelist
https://packages.ubuntu.com/impish/amd6 ... 5/filelist
HarryvL
Post by HarryvL »
vm4dim wrote: Fri Jun 10, 2022 5:55 pm
I tried with
sudo apt-get install libshiboken2-dev/focal-backports
but unfortunately
Release 'focal-backports' for 'libshiboken2-dev' was not found
HarryvL
Post by HarryvL »
wmayer wrote: Fri Jun 10, 2022 3:54 pm A way would be to build the Debian packages for Py3.9 on your own. Therefore download the files
I failed. References are made to Python 3.8 throughout.
A bit of background ... I want to use Intel Distribution for Python to speed up my macro, which is math heavy. I successfully installed this, but can't make FreeCAD to use it.
I successfully created a venv and python --version, python3 -V and python -V all point to the correct Python version. I then followed the advice to set DPYTHON_EXECUTABLE and PYTHON3_EXECUTABLE both to the Intel distribution path, i.e.: /home/harryvl/intel/oneapi/intelpython/python3.9/bin/python3.9. However the Cmake summary for FC keeps giving me:
Summary report
Build type:
Compiler:            /usr/bin/c++ (9.4.0)
Flags:               -Wall -Wextra -Wno-write-strings
Standard:            Requires C++17
Python:              3.8.10 [/usr/bin/python3.8] [.cpython-38-x86_64-linux-gnu]
How can I force the FC build process to refer to the Intel Distribution for Python (3.9)?
Thanks, Harry
mfro
Post by mfro »
Not sure if this post fits into this thread, but anyone else except me affected by Debian Testing's apparent complete removal of all pyside2 packages?
Does anybody by chance know why this happened and when it is supposed to be fixed?
Cheers,
Markus
jeno
Post by jeno »
mfro wrote: Mon Aug 01, 2022 5:22 am Not sure if this post fits into this thread, but anyone else except me affected by Debian Testing's apparent complete removal of all pyside2 packages?
See devel tracker page especially excuses.
It could last a bit longer because the package is involved in an transition (see collisions)
cheers
mfro
Post by mfro »
Thank you. Didn't know that page and sure, testing has its quirks, but I never before had a situation where a complete set of packages just vanished.
Helped myself meanwhile with installing the respective packages from unstable (which I originally wanted to avoid at all circumstances and which might expose its own set of nightmares soon :D ).
Cheers,
Markus
yorik
Founder
Post by yorik »
Just got back from holidays, got my fresh new computer, tried compiling, and fell on the same infamous issue :D
The latest shiboken2 package in Testing (august 23rd) compiles fine with python 3.10 (everything detected, no additional cmake config necessary), but it crashes as soon as a pyside operation is involved (for ex. running a Draft command).
Investigating further...
