FreeCAD on Mac M1?
FreeCAD on Mac M1?
I suspect the answer may be buried in the long BIg Sur thread, but what is the status of FreeCAD on an M1 Mac?
I'm in the market for a new Mac having spilt a Pesi on the keyboard of my 17" MacBook Pro from 2010. I may be able to replace the keyboard, but even Ifixit classifies it as "difficult". (Apple wants $700 to replace it. Part cost is $15!).
Re: FreeCAD on Mac M1?
I've got FreeCAD running using Rosetta2 on the m1 Macbook Air Here's a way to do it:
1. Install Xcode.
2. Open terminal and follow these commands:
3. arch -x86_64 /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homeb ... install.sh)"
3. arch -x86_64 brew tap freecad/freecad
4. arch -x86_64 brew install -s opencascade
5. arch -x86_64 brew install -s freecad
6. freecad
I found the above, allowing installation under Rosetta 2 emulation. What version of FreeCAD does that install?
1. Install Xcode.
6. freecad
That paste is not including the full homebrew path, but if it's the normal tap for FreeCAD, then I believe it's currently set at a 0.19 prerelease git commit f35d30bc58cc2000754d4f30cf29d063416cfb9e.
If you put the commands in code tags using the button </> the URL is preserved.edwilliams16 wrote: ↑Tue Mar 23, 2021 12:14 am 3. arch -x86_64 /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homeb ... install.sh)"
6. freecad[/i]
Thanks Chris
Here is the corrected code from this post https://forum.freecadweb.org/viewtopic. ... 89#p449089
1. Install Xcode.
1. Install Xcode.
arch -x86_64 /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install.sh)"
freecad
i actually just wanted to try freecad on my new m1 computer. then i got an error message that the developer could not be verified. well, there must be a way... i thought. and found these instructions.
in any case, i have now spent 12 hours installing 30gb of data for xcode, crashed my computer several times because something is wrong with opencascade.
this nice short tutorial doesn't seem to be meant for me. i just wanted to try the software....
Please don't give up. Report the error here or in the https://github.com/FreeCAD/homebrew-freecad/issues
Also, remember that macOS has made it very challenging for opensource projects to be compatible with it...perhaps not a coincidence?
- adrianinsaval
I assume you just want to use the precompiled version? did you try the instructions from the github releases page? https://github.com/FreeCAD/FreeCAD/releases/tag/0.19.2bernardvienna wrote: ↑Sat Aug 14, 2021 4:57 pm i actually just wanted to try freecad on my new m1 computer. then i got an error message that the developer could not be verified. well, there must be a way... i thought. and found these instructions.
NOTE: .app is not signed and will not run on MacOS out of the box.
After opening the download, drag the app into your Applications folder (if you already have FreeCAD in there, it is possible to keep both)
When you open the new version, you will get a pop-up saying that it cannot be verified. Do not Move to Bin, simply click Cancel or press Escape key.
Then go to System Preferences > Security and Privacy > General and at the lower part you will see that FreeCAD was blocked from use because it is not from an identified developer
Click the option to Open Anyway
When prompted to confirm, choose Open
If you want to try native Image: FreeCAD_0.20.25491.
import platform
platform.platform()
