chrisb wrote: ↑Thu Feb 25, 2021 8:22 am
Can you provide these versions for the release as well, as soon as it becomes official? I guess the BigSur variant will not run on 10.15 and below, so we have to provide 3 versions?
Gift wrote: ↑Thu Feb 25, 2021 7:54 pm
Ok, I wasn't sure. Your commit is newer than the revision of FreeCAD.
It only changes the start-file (adding the environment variable before launching freecad). The build is done in a seperate step so therefor the freecad-version is older.
It works fine with rosetta 2. The startup is slower. But normal.
We still have the assembly3 workbench included which slows the startup a little bit.
Testing the freecad dmg (conda) on an imac in the store. Seems like it is working quite well. I had no issues with the menu-bar, and also the trackers (pivy graphics) worked smooth (In previous tests I always experienced slow interaction with pivy tracker objects).
looo wrote: ↑Fri Feb 26, 2021 4:03 pm
Testing the freecad dmg (conda) on an imac in the store. Seems like it is working quite well. I had no issues with the menu-bar, and also the trackers (pivy graphics) worked smooth (In previous tests I always experienced slow interaction with pivy tracker objects).IMG_20210226_163817~2.jpg
You bought one?
why should I buy one if you can work from the store . But I have to admit that I would like to have one
