FreeCAD 0.19: macOS Big Sur
Re: FreeCAD 0.19: macOS Big Sur: stuck on launch
Further to my previous post; I've finally managed to generate a log file. Please find attached.
As there is at least one instance running there is hope, see https://forum.freecadweb.org/viewtopic. ... 10#p441848.
The log file is basically the same as the one I posted in this accompanying topic. It hangs on both systems in the line
Log: OpenGL version is: 2.1 (2.1 INTEL-16.0.49)
Vejmarie, should I merge the two topics?
- vejmarie
Might be good yeschrisb wrote: ↑Sun Nov 15, 2020 5:13 pmAs there is at least one instance running there is hope, see https://forum.freecadweb.org/viewtopic. ... 10#p441848.
The log file is basically the same as the one I posted in this accompanying topic. It hangs on both systems in the lineExcept that I have an ATI card instead of INTEL.Code: Select all
- vejmarie
I just build full bigsur FreeCAD based on homebrew. Can you give it a try ? It is available into homebrew-freecad github formula repo.
vejmarie
vejmarie
Thanks for all your work on this. With the caveat that I don't have much experience with Terminal or Homebrew here's what happened:
First attempt ended in an error indicating my CLT did not support MacOS 11 .
Second attempt, after downloading and installing current MacOS CLT package, went much more smoothly and seems to have installed a version of FreeCAD 0.19 that works under Big Sur. Only problem is that the FreeCAD application file was not installed in Applications folder but my workaround is to run it from Terminal using an alias of the FreeCAD exec file.
The attached pdfs are the Terminal logs for the two Homebrew sessions in case you find them useful.
Thanks again.
- vejmarie
All of this seems ok to me. BigSur has introduced also XCode 12.2 which is the developper environment version which support dual architecture. If you upgraded from Catalina to BigSur it looks like that during this process your XCode has not been updated (I am not really surprised by that), which explained why you had to update your Command Line Tools.martin51 wrote: ↑Sun Nov 15, 2020 11:31 pm Hi,
Thanks again.
homebrew is installing its binaries into /usr/local/bin and add the directory into your default path. This is to avoid any potential confusion when removing homebrew from your Mac. I can generate a dmg installable image and perhaps post it to our github release directory but I am not sure that my current credential allows me to do so.
I like the homebrew approach on MacOS as I can use it to recompile dependencies.
Enjoy FreeCAD 0.19 on BigSur and let us know what kind of issues you might met.
vejmarie
Thanks for the work. I hate myself for returning too soon to the previous macOS version .
Worked a charm I temporarily switched to my Parallels Windoze and had to use the mouse. A real pain. Now back in business. Thanks!
P.S. There seem to be some differnt quirks with that build (lots of PropertyPythonObject::toString(): failed for <class 'NoneType'>
<class 'ValueError'>: call stack is not deep enough
popping up and the current window vanishing out of nothing). I guess that's connected with other things being done in that build. But basically it works under Big Sur.
- vejmarie
Hiqwerty_f wrote: ↑Mon Nov 16, 2020 9:47 am Worked a charm I temporarily switched to my Parallels Windoze and had to use the mouse. A real pain. Now back in business. Thanks!
Thanks for the feedback. I liked to track the python object to string error. Is it appearing by using the specific workbench ? Could you post a full copy of the message when you got it ? Can you also confirm me that you have python 3.9 installed only or multiple version ? Brew search python will help you to determine that !
Vejmarie
FreeCAD running on Big Sur!! Thank you for all your work on this. I generally had some minor error messages on start under Catalina, now everything is happy.
Thank you!!
