compile FreeCAD on Windwos with conda
I have seen some instructions to compile FreeCAD on conda on Windows on the forum. User _UR did this on regulary basis. Does anyone know where to find these informations?
cheers bernd
cheers bernd
Re: compile FreeCAD on Windwos with conda
found these two links ...
https://forum.freecadweb.org/viewtopic. ... 20#p250135
https://forum.freecadweb.org/viewtopic. ... 20#p258365
and this interesting abut conda
https://jakevdp.github.io/blog/2016/08/ ... nceptions/
Is it right, that the easiest way to get latest FC binaries under Windows - is to install Anaconda/Miniconda and pull-compile GIT source under it?
No it is not! https://freecadweb.org/downloads.php scroll down a bit to dev releases!Smiling_user wrote: ↑Sat Aug 08, 2020 6:27 am Is it right, that the easiest way to get latest FC binaries under Windows - is to install Anaconda/Miniconda and pull-compile GIT source under it?
This place is well known, but there is a release from 2019.11/bernd wrote: ↑Sat Aug 08, 2020 7:36 amNo it is not! https://freecadweb.org/downloads.php scroll down a bit to dev releases!Smiling_user wrote: ↑Sat Aug 08, 2020 6:27 am Is it right, that the easiest way to get latest FC binaries under Windows - is to install Anaconda/Miniconda and pull-compile GIT source under it?
It seems the first post is out of date. I hadn't tried this lately. I'll try to get it working and add to the wiki. Probably just need to pin the version of some package(s)
"fight the good fight"
Something that I have noticed for quite a while is the "Assets" link for 0.19 typically remains closed when opening the releases page. Some of the older versions show the full Assets upon opening.
There have been a few "cannot find it" posts in the Help Forum for exactly that reason.
I do not know if there is a way to make the "Assets" automatically open, but it would be helpful it that could be done.
The date on the top is confusing, but most people would be OK if they saw the available downloads.
Gene
