sounds reasonable to me.wmayer wrote: OK the good point is that this is not a bug in FreeCAD, the bad point it's probably a bug in the OpenCascade library.
Sorry, I mixed up the console...wmayer wrote: I guess this bug only appears with the 64-bit but not with 32-bit version because AFAIK all the people who have tested the sample project file have the 32-bit version.
That was 32-bit
I have uploaded all files: (maybe someone can check these)wmayer wrote: To make this sure you should check that your IGES,STEP, BREP files are not corrupted. If possible it would be best to test this with a 32-bit OpenCascade.
http://www.spranger.biz/~bene/testa.brep
http://www.spranger.biz/~bene/testa.fcstd
http://www.spranger.biz/~bene/testa.iges
http://www.spranger.biz/~bene/testa.step
Bis denne
Bene
