Im on this moment the maintainer of freecad for gentoo.
When one of the user starts freecad He gets this error:
freecad start error :
$ FreeCAD -l
FreeCAD 0.9, Libs: 0.9R2646
(c) Juergen Riegel, Werner Mayer 2001-2009
Could not open catalog:
XercesMessages_en_US.cat
or XercesMessages_en_US.cat
Cannot load message domain
Qt: Session management error: Could not open network socket
Have you seen this earlier and do you know the answer ?
Roelof
run error
Re: run error
The first look likes the xercesc package is not proper installed (it can't find some of its files).
Let him check if some other programs using XercesC works...
The last I didn't seen bevore. Looks like Qt try to connect some Desktop environment!?
Stop whining - start coding!
Re: run error
xerces: sounds like an issue on Gentoo. Get more information at http://bugs.gentoo.org/259408 (where another app runs into the same problem)
Qt: Does the trick solve this issue? http://www.linuxquestions.org/questions ... et-287176/
Werner
Werner
Re: run error
HOi,
Reinstall of Xerces-c did the trick.
But thanks for the tip.
ROelof
ROelof
