I could compile with success using those instructions :
http://sourceforge.net/apps/mediawiki/f ... rmic_Koala
But I had a lot of unusable items. I think because Pivy was missing as it is not in kubuntu repository.
I tried those instructions :
http://sourceforge.net/apps/mediawiki/f ... llation_2
I installed manually, as specified the old version of Swing (1.3.25) and then the command
python setup.py build
pivy/coin_wrap.cpp:344456: error: no matching function for call to ‘SoRenderManager::removeSuperimposition(Superimposition*&)’
/usr/include/Inventor/SoRenderManager.h:118: note: candidates are: void SoRenderManager::removeSuperimposition(SoRenderManager::Superimposition*)
error: command 'gcc' failed with exit status 1
Warning: Pivy has only been tested with the following SWIG versions: 1.3.31 1.3.33 1.3.35.
Now I don't know what to do and seek advice...
Kind regards
