File>Export>Step: DLL load failed
STEPERADO
Post by STEPERADO »
Installed from FreeCAD_0.8.2237_installer.msi
Ran from Start>Programs>FreeCAD 0.8>FreeCAd
Ran File>Import on .stl file.
Ran File>Export
Following appears in output:
Exception (Thu Aug 20 09:50:14 2009): DLL load failed: The specified procedure could not be found.
Stack Trace: Traceback (most recent call last):
File "<string>", line 3, in <module>
Similar message appears with the following menu commands also:
View>Workbench>2d Drafting
View>Workbench>CAM Design
View>Workbench>Complete
View>Workbench>Part
View>Workbench>Part Design
View>Workbench>Raytracing
View>Workbench>Sketcher
Founder
Re: File>Export>Step: DLL load failed
Post by wmayer »
the MSI installer actually is OK. Do you have installed OpenCascade or another applications that uses OpenCascade somewhere on your system?
Werner
