How to edit imported IFC files in FreeCAD
This forum section is only for IFC-related issues
bitacovir
Post by bitacovir »
I exported a IFC file fom FreeCAD, but when I import the same file in FreeCAD I cannot edit the geometries. Is there are method to edit imported IFC files in FreeCAD?
Wall ejm 01.ifc
(25.32 KiB) Downloaded 78 times
Wall ejm 01.FCStd
(70.87 KiB) Downloaded 70 times
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: English/United States (en_US) [ OS: Spanish/Spain (es_ES) ]
Installed mods:
  * sheetmetal 0.2.49
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
yorik
Founder
Re: How to edit imported IFC files in FreeCAD
Post by yorik »
You need to disable the multithread importer, and set import style to "Parametric Arch objects". The multithread importer just generates shapes and doesn't try to recreate the extrusions, etc.
That's actually something I'm exploring (specially within https://github.com/yorikvanhavre/BIM_Wo ... /issues/94 : What if all the file is imported as simple, dumb shapes, and you had a kind of "reextrude" tool to "reconstruct" the extrusion on demand? We would keep most of the model simple and fast, and still would be able to edit anything, even shapes that were not editable in the IFC file..
paullee
Post by paullee »
'On demand' sounds to be a good idea :)
Maybe a checkbox / switch in the import dialogue for users to pick upon importing ?
bitacovir
Post by bitacovir »
yorik wrote: Tue Jul 05, 2022 2:32 pm That's actually something I'm exploring (specially within https://github.com/yorikvanhavre/BIM_Wo ... /issues/94 : What if all the file is imported as simple, dumb shapes, and you had a kind of "reextrude" tool to "reconstruct" the extrusion on demand? We would keep most of the model simple and fast, and still would be able to edit anything, even shapes that were not editable in the IFC file..
That could be very powerfull, because not only you can select what to edit, you could have a tracker system with a record of the editions in the file...
::bitacovir::
bitacovir
Post by bitacovir »
yorik wrote: Tue Jul 05, 2022 2:32 pm You need to disable the multithread importer,
How? I don't see the option in preference- import/export - IFC import
::bitacovir::
thomas-neemann
Post by thomas-neemann »
bitacovir wrote: Tue Jul 05, 2022 1:11 pm ...
if you want to export geometry for someone else to continue working with, stp or iges is more appropriate. ifc is intended for bim processes, only the authors of the ifc files change them by always creating a new one
