(SOLVED) Import problem with ifc4 ?
This forum section is only for IFC-related issues
thomas-neemann
Post by thomas-neemann »
I get this message
if i want to import this ifc4 file,
https://grabcad.com/library/convenience-store-1
and the import stops
Can anybody confirm this?
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.29045 (Git) AppImage
Branch: (HEAD detached at bbc47e7)
Hash: bbc47e75c6836410a53518917cd5710ec89c7018
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Last edited by thomas-neemann on Thu Jun 09, 2022 6:58 pm, edited 1 time in total.
thomas-neemann
Re: Import problem with ifc4 ?
ifcplusplus
linux (ubuntu) installation and start:
sudo apt update
sudo apt -y install ifcplusplus
SimpleViewerExample
imported it, but apparently not completely. could be that the file is defective
thomas-neemann
everything seems to work with ifc 4. here is an example
https://github.com/RWTH-E3D/DigitalHub
thomas-neemann
Re: (SOLVED) Import problem with ifc4 ?
even ifc4x2 is imported. ifcplusplus cannot do that yet
https://ifcinfra.de/wp-content/uploads/ ... odel01.zip
thomas-neemann
IfcConvert can convert the file, once you import and export the dae result in blender, even the colors are adopted
edit
example
https://forum.freecadweb.org/viewtopic. ... 84#p601347
