I imported an IFC with 230MB into Freecad.
The Import need 9h and resulted in a Freecad File with 1.7GB in size.
The experimental import settings for using multicore was active.
Any suggestion how to imporve the importing?
performance importing IFC
- Kartoffelpüre
- thomas-neemann
Re: performance importing IFC
Kartoffelpüre wrote: ↑Fri Apr 22, 2022 9:03 am I imported an IFC with 230MB into Freecad.
if only the geometry is needed, e.g. this could help for referencing a connection construction, which is normally done in the bim process:
https://forum.freecadweb.org/viewtopic. ... 00#p416830
https://forum.freecadweb.org/viewtopic. ... fc#p419642
